Results 1 to 10 of 10
Thread: Ex Chaser Info
    VT SS 5.7 Ex-Chaser
    Jan 2010
    Default Ex Chaser Info
    I recenlty bought a VT SS 5.7. I later found out that it was an ex chaser and was told that they had work done to them when being built. Does anyone know if this is true and if so what work is done to the car?
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    nothing performance wise if thats what your thinking,im pretty sure just things like sump protector plate,bit of extra wiring for the lights and sirens etc
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    There were two National Police packs available for VT Series Models; Production Options (P.O.) 9C1 and A8V.
    Here's how to read the VT model number on the build plate:
    VT 8VK 35-9C1-1PT (Sample Model)
    VT = VT Series Model
    8VK = Executive (including SS)
    35 = Wagon
    69 = Sedan
    9C1 = Nation police pack (Executive)
    824 = Automatic transmission SS pack
    825 = Manual transmission SS pack
    1PC = Base police pack (Executive)
    1PT = Base police pack plus power operated windows (Executive)
    8PC = Base police pack (SS)
    8PT = Base police pack plus power operated windows (SS)
    If i'm thinking yours is the one it is, it will be a Series 2 SS. Should be an auto, however manual was an option for it.
    Came with:
    Air conditioning
    Dome and map reading lamp
    Police certified instrument cluster
    Sports suspension
    Dual air bags (SRS)
    Antilock brake system (ABS)
    Removed Traction Control from SS Models with P.O. A8V
    Spin resistant differential (LSD)
    Modified gate automatic transmission control
    Heavy duty battery (V8 only) Century 520 CCA
    Quick release battery terminals
    140 amp Mitsuibishi generator (GEN III V8 only)
    Interior lights out function (override switch on I/P facia)
    Auxiliary wiring harness (located in engine bay)
    25 mm cable hole and plug (LHS cockpit module)
    Dual horns
    Cruise Control
    Power windows
    Sump Guard
    Alloy wheels – 8.0 J x 17
    235 / 45 x 17 R-ST-TL
    Automatic transmission oil cooler (V8 only)
    Yours being a Gen 3 also had a different MEMCAL fitted. Not sure if you've still got it though, basically the way to tell is if your vehicle idles at 850RPM instead of 650RPM. There is only tiny adjustments in it though, nothing big to get awesome performance.
    VT II exec wagon VX SS wheels
    Jul 2006
    Central Coast NSW
    Default VT Seats
    Hi Guys, The drivers seat in my VT exec is starting to collapse. The outside edge is pretty ordinary. So im going to buy another from the wreckers, but am thinking now about replacing both front seats with leather ones out of a wh stato. Is the passenger side easy enough to connect up or doesn't the exec have the wiring loom on the passenger side?
    Thanks Dave
    Jul 2006
    Central Coast NSW
    rickybobby's Avatar
    rickybobby is offline shake 'n' bake
    VN S1 V6 T5, VR V8 T5
    Aug 2008
    MEL
    tried searching for VR police pack model numbers
    anybody got same info as per VT details above
    much appreciated
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by rickybobby View Post
    much appreciated
    BT1 to start with, prehaps post a thread in VR,VS section for more details.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    I'll post the info for him.
    Take one white VR Exec. Thrash it for the first year of its life, drive over gutters at speed, whack into gutters, R-1st'ies, then sell to joe public.
    To summarise, you have the same car as every other VR on the road, theirs is just in better condition.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by alien View Post
    No such thing.
    WK Statesman V8
    Mar 2010
    Im sure that there is a wiriing section that you need to buy from a wrecker or holden to make it the 8 way seats work
  1. ex chaser vy
    By shano8 in forum Electrical Wiring / Questions
    Last Post: 20-11-2008, 04:33 PM
  2. ex chaser
    By shano8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-10-2008, 12:57 PM
  3. ex chaser chip
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2007, 10:28 AM
  4. 16 inch chaser
    By commodore2004 in forum Swap / Wanted to Buy / Trade
    Last Post: 10-11-2006, 01:54 PM
  5. vh ex chaser??
    By bitch in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-10-2006, 08:54 PM
