Results 1 to 9 of 9
Thread: gen 3 oil leak need help
    vt executive
    Jul 2009
    Default gen 3 oil leak need help
    my vt 5.7 is leaking oil from the side of the block near where tranny bolts on passanger side. theres 4 bolts 2 with bolt heads and 2 with allen key heads in a straight line, what are the bolts for? could it be leaking from there. we degreased engine but still seems from those bolts.
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Could be a number of things...
    Leaking inlet manifold gasket...
    Leaking crank angle sensor...located at rear of engine.
    Leaking oil pressure switch located close to crank sensor.
    Could be rear main or sump gasket leaking...
    Leaking rocker cover gaskets.
    Your best option would be to remove the the top engine coaver and lower stone guard and give the engine a good wash,also trying to avoid heavy wetting of the electrical components eg ignition coils.
    Then drive around for a week and observe where the oil is leaking from.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    vt executive
    Jul 2009
    i can see the oil comeing out of thoses bolts just dont know what they are for
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    leaking sump I would say
    if its the bolts I think you are talking about mine leaks at the same spot as well
    cheers GM
    vt executive
    Jul 2009
    its on the side of the motor just in front of the gearbox there is 4 bolts side be side2 with bolt heads and 2 with allen key heads they look like they dont do any thing
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    vt executive
    Jul 2009
    GM GEN3's Avatar
    GM GEN3 is offline GM GEN3
    legs ATM
    Sep 2008
    S.A
    have u tried doing them up a bit cos alot of the time they come loose from drving mine leak from the same thing did it up neva leaked again
    vt executive
    Jul 2009
    yea i did the outer ones up cant get 2 alan key ones trany lines in the way do u fnow what they for?
  1. oil leak
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-08-2008, 05:25 PM
  2. Oil Leak
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 06:23 PM
  3. Oil leak
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2007, 11:48 AM
  4. Oil Leak
    By mikemutlow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2006, 06:43 PM
  5. Oil leak on VS
    By julandi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2005, 07:50 PM
