Results 1 to 13 of 13
Thread: VT drive belt squeal at idle
    vt 3.8
    Jan 2010
    Default VT drive belt squeal at idle
    My mate has a vt v6 and the drive belt squeals at idle . Checked all the pullys and their fine cleaned everything up and fitted a new belt and the noise is still their. The water pump has a liitle play and the harmonic balancer has some movment back and forth but doesnt wobble. When you raise the revs the squeal goes away. Anyone have some suggestions?
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    As long as the belt is at the correct tension, I wouldn't go replacing everything.
    There is a product that is meant to stop belt squel and/or slippage. You can buy that sort of stuff at Repco, Supercheap, Autobarn etc. Go down and have a look.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    GT
    Unfortunately belt squeal is something which affects many V6 Commodores and will be especially noticeable when the belt is cold or damp. (I never experienced it on my VT or VX though).
    You can try purchasing a can of "Belt Grip". Remove the belt and give it a couple of very light sprays and let it dry well between applications and before installation.
    This may solve the problem for a while but it will return.
    There are some other remedies that people try but I would not recommend them because they involve some lubrication of the belt in which event you may well suffer belt slippage.
    It is worth double checking the pulleys attached to the belt tensioners to ensure these are not contributing to the noise.
    vt 3.8
    Jan 2010
    Mate says it has quiten down a bit since driving with the new belt. I repacked 2 of the pullys with new grease. Still to do the tensioner pully.
    VL V8 & supercharged VX
    Nov 2006
    western vic
    heres what u do get some metho wipe on belt and pulleys and then get silicon spray then u will never have that problem again.
    VT 2
    Nov 2008
    '98 V6 VT Berlina
    Nov 2009
    Quote Originally Posted by Tsunamix View Post
    Scuff up any pulley surfaces which are heavily polished.
    +1
    Might pay to clean them first with metho in case you've spilt coolant over them (renown for causing belt squealing).
    Wash the serpentine belt in some warm soapy water and rinse well.
    GM GEN3's Avatar
    GM GEN3 is offline GM GEN3
    legs ATM
    Sep 2008
    S.A
    mine was making a bit on noise i sprayed it and started the car up worked fine no noise
    Dr.304 is offline SuperCharged StatesMan
    1997 VS Statesman Supercharged
    Feb 2007
    Oz
    get a bar of soap and rub it on the belt while it is running. The squeal should dissapear right before your eyes and ears.
    *Not a permanent fix*
    vt 3.8
    Jan 2010
    Mate came over today as the noise has been occuring whilst driving now and we have isolated it to the water pump. The bearing seal has gone on the inside i asume and the bearing has dried out. Fitting a new water pump tomorrow. Will post a reply tomorro.
    VT executive V6
    Dec 2009
    vt 3.8
    Jan 2010
    Noise has gone. When i took the old pump off i noticed it had been leaking. Mate had recently put stop leak in radiator (heater valve leaking)which had stopped the water pump seal from leaking and this has caused the bearings to dry up.Pump was easy to replace. So now has new water pump heater valve thermastat and coolant and is running well again.
    VT
    Feb 2010
    I had the same problem with a noisy belt, I would of swarn it was the belt squeaking I even got some of that stop sqeak spray and it did stop it for a short time,,
    It turned out to be the top Idler pully I even took it off and spun it and it didn't sqeak but when it was on the car under presser it did.
  1. Belt Squeal at and above 2500 rpm?
    By Timlee03Vyberlina in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-05-2009, 06:13 PM
  2. VU SS Belt Squeal ??
    By JamesVUSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2009, 06:30 PM
  3. New drive belt
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2008, 10:51 PM
  4. Drive Belt.
    By Tam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 07:49 PM
  5. Supercharger belt squeal
    By rantin'n'raven in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2008, 08:12 PM
