Hi there i have a 98 VT commodore witch i am currently doing mods to and i am just wondering how i could posibly install an Xbox and a small plasma or LCD screen into it in the front passenger side..
Any help will be welcome![]()
thanks
Brad
There is a series of articals on Autospeed.com about setting up an in car PC system. The artical is quiet old, however I believe the information in it would proove to be quite valuable, and would apply to something like an xbox also. Check it out!
The first of the series is in the link below:
Part One
Part Two:
Part Two
Part Three:
Part Three
Part Four:
Part Four
Good Luck!
151 Countries, One Cúl-Báire!
Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
Cúl's AUII XR8 Ute!!!... Clicky Clicky!
I think it would be relativly straight forward..... How ever i dont think you can install a screen into the dash on the passanger side as the Air Bag is there.
This is what i would do.
I would rip the center arm rest out and mold the Xbox into there. (you will obvisioly need a power inverter to run it so don't forget him)
Most 7" Double din Head Decks have RCA in so you can hook it up to it or i would be hooking it up to a roof mount 12" / 15" as they also have RCA in.
If your going to use a 360 (which is presume) it should be pretty easy as there slim line. BUT remember that where ever you put it you want to keep it cool as they dont do to well in hot/ Moist conditions.
not sure if this will help ya at all but here's where i put my 7' lcd tv/av input -so can plug whatever ya want into it, mines just hooked up to the dvd/cd head unit(under it) with av plug coming out as well so i can plug nokia phone into it for mp3, gps maps, or game's if board,
it all fit in pretty easy, bit of cutting and stuffing around but looks neat.
my mate has an xbox 306, i dont recomend putting it in, put a ps3 in, xbox 360 doesnt have anti shock for its games, where as ps3 does![]()
get the new slim line PS3 doesn,t heat up as much nsw screens have to be in the back cause if the driver can see it u can be booked for it being on while driving. stick an inverter in the boot and run your sound through your amp i have seen the ps3 and xboxs mounted in the boot access hole all nice and neat with twin overhead screens/dvd player. have seen a set up that slides outa the glove box then flips downward with ps3/xbox mounted in kick panel (custom fibreglass) also cool
Thanks for all your helpI am looking for around an 8 inch screen to put it into the glove box.
Given the power consumption and heat given off by an Xbox 360, it would be a very bad idea to put one in a car.
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
and research power suplys aswell. i had a fun time getting my ps2 to work in my vx. the power inverter needs to be on a spacific sign wave or something to make it convert the power from dc to ac properly. i ended up buying a power suply off ebay and it works a treat. but definalty do your research on the power suply before you start or u will be disappointed. talk to jaycar they have the parts needed.
