Results 1 to 7 of 7
Thread: side mirror indicator installation help!!!
    '99 VT
    Nov 2008
    south east melbourne
    Default side mirror indicator installation help!!!
    I've got a pair of side mirrors which have indicators on them. I need some help on how to go about connecting them to the indicator. Im sure the drivers side would be pretty straight forward but for the passenger maybe a little tricky.
    Any advise would be welcome, if you need to know the wiring specs just ask me there are two sets, one for the electric adjustment and the other for the indicator lights, not sure which is which...
    '99 VT
    Nov 2008
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    You just answered your own question.
    Run a wire through to the door from he gaurd on each side.
    '99 VT
    Nov 2008
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Jack the car up, remove the wheel and inner gaurd trim and youll have plenty of room.
    Remove the rubber and feed the new wire through it
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I think you would need to remove the splash guard which is the plastic lining in the wheel arch. Maybe you can do it by removing the side indicators ( you can lever them out) and feed a wire through from there.
    Edit. A tad late
    MY RIDE
    '99 VT
    Nov 2008
    Thanks for the help guys but i actually found an easier way. You can see the side indicator light wire from opening the driver (or passenger) door. Its easy enough to reach with a coat hanger and pull it through.
  1. how to fix side mirror?
    By tim69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2009, 01:37 PM
  2. I need help on a side mirror replacement.
    By ballzy1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2008, 09:59 AM
  3. Side mirror compatibility
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2007, 01:43 PM
  4. shaky side mirror???
    By werdy666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2005, 01:05 PM
  5. Vn Lhs Side Mirror
    By VN_BLUE_S-Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2005, 09:13 PM
