Hello Members,
My lady's high k's, 310,000km, otherwise mint, 00VX v6 , Berlina wagon has just started leaking coolant from the rear of the engine, very slow drips really and noticable as the glycol green water gathers and drips from the outer corners of the stone guard plate between between the block and transmission visible from underneath.
Is anyone aware of the possible cause and or the likley cause of this fault?
Apologies if this has been asked previously, had a good look but could not find a specific match.
Thank you for any assistance with this.
could be a few things heater hose ,heater tap just have to try and find it mate
common as hell actually but inbetween the transmission and engine is a rear main seal and plate as an assembly which does leak exaclty as you described, is a transmission out job i did mine at 200,000kms. good luck.
