do the vx ss badges clip in i need to replace old ones because the chrome is coming off them can someone tell me how to take them off and how to put new ones back on do you put glue on them or do they clip in
no clips just stuck on and the new ones have double sided tape just be carefull no to take the paint off
Very easy to remove, you can search the How to Threads but in a short cut just Heat up the badge with a Hairdryer and get a peace of fishing line and gentle put the line behind the badge and rock the line back and forth ( Left & Right) until you have cut through the double sided tape holding the old badge on.
Get some Goo remover to clean up the left over glue and give it a quick Polish then re aply the new badge.
Its a good idea to mark out a template of where the old badge was before you remove it so the new badge goes back in the same spot and angle.
