Results 1 to 7 of 7
Thread: VX Exec V6 randomly cutting out
    VX S1 Exec
    Aug 2004
    Default VX Exec V6 randomly cutting out
    Hi,
    I am having a problem with my vx commodore. Occasionaly it will stutter momentarily, and then continue on it's way, and on two occasions, it has stopped altogether whilst driving.
    Most recently it happened this morning whilst my Fiance was driving it. I cant have this happen!
    From searching I have found that the most likely candidate is the Crank Angle Sensor. How would I determine this conclusively? I found the document from Airstrike that details how to read the error codes, and I will do this tonight. What codes should I look for to pin point CAS?
    I appreciate any and comments and feedback
    VX L67, ln106 hilux, xr600r
    Jun 2009
    qld
    1998 VT Acclaim S1
    Feb 2008
    Another possibility is if the connector contacts to your fuel pump is loose or dirty. Give it a clean and see how you go. Otherwise it could be your fuel pump thats on its last legs.
    VX S1 Exec
    Aug 2004
    Youtube video of the fault codes:
    YouTube - VID 00001-20100202-1850.3GP
    I'm such a gump, I dont quite get how to read them properly!
    I could have sworn one of the flashes went to 10!
    Ideas?
    Edit:
    I count:
    1 3 7 2 (3 times)
    10 3 7 4 (3 times)
    What does that mean?
    VX S1 Exec
    Aug 2004
    Booked into Holden Today.
    And the verdict is (insert drum roll here)
    **** CRANK ANGLE Sensor! *****
    He also mentioned that the inlet manifold and throttle body need cleaning, but i'll do that!
    Jun 2009
    qld
    VT Wagon
    Nov 2008
    I think I have a similar issue.
    One day about 6 months ago my car had trouble starting, took a good 5 or 6 seconds of cranking and ever since then it's been the same.
    More recently, it would start up fine after the long cranking but then as would try and drive off it would go a few meteres then almost cut out before resuming normal revs.
    A week or so ago I noticed that it had almost no power when I put my foot down, like it had a "power leak".
    Two days ago it almost cut out when I took of at the lights and then tonight it almost stalled in neutral after I started it and then I parked it at a servo after a 15 minute drive, started it again two minutes later and as I turned out on to the road all the power drained away again and it almost stalled.
    Do you guys reckon I'm looking at a CAS or fuel pump or both?
    How hard is it to swap the CAS over yourself?
  1. VS V6 cutting out randomly
    By vshilux in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2011, 12:20 AM
  2. VX overheating randomly...
    By SMOTAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2009, 03:05 PM
  3. Replies: 11
    Last Post: 27-02-2009, 11:53 PM
  4. Car Alarm going of randomly
    By Hodz91 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2009, 09:57 PM
  5. Speakers cutting out in VT randomly
    By And_ROOS in forum Car Audio
    Last Post: 27-01-2009, 08:42 PM
