Results 1 to 12 of 12
Thread: Am i crazy?
    VT Berlina
    Jan 2010
    Default Am i crazy?
    Hey guys got a tricky one for ya.... kinda.
    My VT Berlina has a relatively rough idle, not too bad but low enough to be annoying, around 4-500 rpm. ive just cleaned my TB, Idle Speed Control thingo etc hoping it would fix it up a little but no improvements on idle, just a bit more responsive.. also just replaced plugs and leads and no deal..
    Am i crazy and is 4-500 normal or could it be in need of a little tune or somethin?
    Thanks for tickling my curiosity!!
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Mark1990 View Post
    have you checked your coils and dfi? they could be on their way out, also does it fire up straight away when u start it or is it slow?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VT Berlina
    Jan 2010
    Nup havent checked them and wouldnt have a clue how! it starts easy as, no probs! how do i check the coils... and at the risk of sounding retarded..... what is the DFI?
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    DFI is what ya coils are sitting on, im not too sure how ya check them properly ill let someone else answer that, dont wanna give you wrong info lol, also did u make sure all the leads and fitting on the plugs and coils properly?
    VT Berlina
    Jan 2010
    yeah pretty positive the leads are plugged into the spark plugs right, the heat shields can be wriggled around a little which made me worry at first but a good yank on the end doesnt bring it off the plug and they seem tight!!!!!
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ahhh kk just wait til a few other people give their thoughts on what it mite be
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Is it rough (like spluttering or missing) or just low.
    Ronald Reagan (1986)
    VT Berlina
    Jan 2010
    nah not rough, like i said nothing really BAD, just annoying, cuising some dash vibrations and stuff (which could be due to it being pulled out before i bought the car to cram a dvd player in), but just thought 500 may be a bit low and a couple of hundred higher the vibrations etc stop haha
    Oh and sorryn no not missing or spluttering. how can i tell if my engine mounts are worn?
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Is that with it in gear or when its parked?
    500 RPM sounds about right when in gear and it should be at about 800 RPM when in Park.
    What happens when you turn on the A/C?
    If it doesn't correct itself I would be leaning towards the IAC (Idle air control) valve which is mounted to the throttle body
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VT Berlina
    Jan 2010
    yeah i cleaned the IAC. and what you said sounds spot on, its around 500 in gear, 800 in park.... which solves my mistery... i AM crazy.
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    If it is causing the vibration then it could be possibly the engine and transmission mounts are stuffed or you could have a torque converter on its way out or loose.
    JCCC NSW Member
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    500 sounds low to me, normal idle is closer to 700. It should be printed on the orange sticker on the radiator shroud.
    It's not manually adjustable, if it's not idling right it's probably got a problem somewhere.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  1. rev crazy
    By 5ivespeed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 06:14 PM
  2. VZ Sv6 ute goes crazy
    By mattieschwarz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2007, 01:11 AM
  3. CRAZY CRAZY ABABS!!! nutters, seriously
    By MikeVXSS in forum The Pub
    Last Post: 02-12-2006, 06:46 PM
  4. Crazy Cat
    By HoZy in forum Jokes/Humour
    Last Post: 02-06-2006, 11:23 AM
  5. crazy bus
    By hakhawk in forum The Pub
    Last Post: 23-05-2005, 12:00 AM
