Results 1 to 3 of 3
Thread: Air/Con problem
    VT Berlina S2
    Nov 2009
    Default Air/Con problem
    Hi guys
    Had my Air Con serviced a few months back, all was working perfectly etc
    Went on a holiday a few weeks back and the car wasnt used for 1 week, come back from holidays and the air/con is no longer cool
    It turns on fine, the fans work fine, and i can hear the compressor kicking in when started.
    Any ideas on what it could be? Can the gas leak the entire contents in one week?
    Thanks in advance.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If the leak is big enough it can leak all the gas but if there is no gas the compressor shouldn't kick in due to the low pressure switch. Check to see that the heater tap is working properly because if it is not stopping hot coolant from flowing through the heater core the aircon can't do it's job as hot air and cold air will mix and make warm air.
    MY RIDE
    VT Berlina S2
    Nov 2009
    Quote Originally Posted by accentstencil View Post
    Thanks very much for the suggestion, ill check the heater tap
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. Is this a problem????
    By cjwau in forum V8 Development and Modification
    Last Post: 21-11-2009, 09:55 PM
  3. Key Problem
    By faisal27 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2009, 04:56 PM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
