Results 1 to 9 of 9
Thread: Vibrating when driving
    VY Berlina Series 2 5.7l
    Oct 2009
    Question Vibrating when driving
    Hi all,
    Was driving VX ute yesterday when driving up i step hill all of a sudden it dropped back a gear and the revs went up to about 4500 then after that the whole car had a shakey feel the floor, pedals etc etc. I have a feeling it may be the tranny? It has just clocked over 280,000 and is due for a service. But have noticed the exhaust is making like a pop noise. I did put fuel in it about 30 mins before this happened. Was raining and alot of water on the ground possible that water had got into the servo fuel tanks?
    I checked the tranny fluid and its pretty dark not the normal lite pink and doesn't have a sweet smell like my other cars. Not a full burnt smell to it but close.
    Any ideas?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Is it a vibration or shaking? Does it only do it in top gear?
    MY RIDE
    Oct 2009
    Both mate. Its pretty bad once i got out of the car i could still feel the vibrating in my legs. It even does it at start up. Once u get up to 80km it sounds like a chopper flying overhead. Also shaky steering wheel to.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Then it sounds to me like stuffed engine mount(s). Chech them out to see if they are broken or sagging causing the sump to kit the crossmember.
    MY RIDE
    VT
    May 2009
    Had the exact same problem when I bought my VX It was doing weird thinks like that I thought it was the tranny but one day about 2 months later it started to run on 4 cylinders found out it was a coil pack the whole time.
    Oct 2009
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Michael_123 View Post
    Ok will do. Would it be risky driving it?
    If the sump is hitting the crossmember you could do damage. If it is a broken mount you could drive it carefully but I would fix it urgently. The mounts are designed so the engine can't fall out but there would be quite a bit of movement. The best thing to do is get under the car and use a lever near the mounts and see how much movement there is.
    MY RIDE
    Oct 2009
    VT Commodore
    Feb 2010
    "Vibrating when driving"
    Bet the missus isnt complaining :P
  1. vibrating tacky noise
    By vt rob in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2009, 05:29 PM
  2. Vibrating
    By skinnyscotton in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2008, 07:56 AM
  3. Little Help: Surging / Vibrating
    By Necrum_McDirk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 10:07 PM
  4. Vibrating car
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 05:16 PM
  5. Vibrating VS.....HELP im going nutZ
    By ghostVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 08:41 PM
