Results 1 to 5 of 5
Thread: VT pully wheel -how hard do you pull a pully
    VT commodore v6 exec
    Feb 2010
    Cool VT pully wheel -how hard do you pull a pully
    am taking out the water pump on my vt v6 series II exec and need to pull off the idler pully to to get the last nut off the pump.
    Nut was very hard to remove.......
    attual pully wheel.... any way I try to lever it from behind feels like its gunna do damage!!
    any tricks, have drowned it in WD already.................hmmmm no silly little grub screws behind there is there.......might go have a feel.....no...nothing arousing
    Help !!!!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It should just slide off but is probably corroded on there. Try and lever it off from 2 opposite sides at the one time.
    MY RIDE
    Feb 2010
    Yeah I think you are right, must be corroded on very tight, will use the tap wiggle and lever method for a bit, am worried i will buckle the wheel if i use too much force.....thanks
    Feb 2010
    WoooHooo! Tap, tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap, wiggle.... it came off, just needed a higher balance of taps to wiggles ratio.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by wildwabbit View Post
    Well done. Give the shaft a good clean and apply some grease so it is easier next time you need to replace the pulley.
    MY RIDE
  1. 00 vt main pully wheel
    By weazzellboi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2010, 07:40 PM
  2. Gilmer Pully? 3.8L
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2008, 04:59 PM
  3. Air con pully removal
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2006, 04:35 PM
  4. Replacing SC14 stock pully with an alternator pully ?
    By gemini in forum General Discussion
    Last Post: 08-05-2006, 04:02 PM
  5. A/C pully..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-03-2006, 12:14 AM
