Results 1 to 11 of 11
Thread: vt radiator hose busted
    VH, VL, VT, 74 monte carlo,75 dropped effy
    Aug 2009
    city of gosnells
    Default vt radiator hose busted
    my musses vt top rad. hose busted , i put a new hose on but shes tellin me i have to fill the bottle to the right that says "coolant". so do i put it in there or do i take the cap off and it in the top of the radiator? any help appreciated, thanks guys
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Goes in the cap on top of the radiator. Make sure you keep an eye on the levels as you have to keep toping it up as there will be air in the system.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    VY II V6
    Dec 2006
    There's also a bleed screw at the top of the thermostat housing, at the other end of the top hose. Best to fill it up cold, put the cap back on, undo bleeder screw only a few turns, let the car idle until hot, wait for coolant to weep out of the bleeder, tighten up the bleeder and check the coolant once its cold again..
    -Nick.
    Aug 2009
    city of gosnells
    99 VT Acclaim Wgn V6 Auto
    Jan 2007
    Hi guys
    My radiator got replaced last week and all's been well. When I got home today, I opened the bonnet and it looked like someone pissed coolant all over my engine!!!!!!!!! Inch long split at the thermostat end of the top radiator hose! Mustve just happened as I drove up the driveway! Lucky
    Gonna get a new hose tomorrow. Looks simple enough;take off clamps, old hose off, new hose on, clamps back on. Now, I was once told with my VP to take off the radiator cap as S.T.K.E said when the car is cold, fill to the top, start the car and wait till the thermostat lets go and sends it thru the engine, then fill with coolant till it hits the bottom of the radiator cap neck and stops bubbling then put the cap on. Will this work or should I use the bleeder valve as 'nick' said?
    vhmarbleface, how did you go about replacing your hose?
    Any help most welcome
    P.S. I know this is probably VT Commodore kindergarten stuff, but the cowling on the top of the engine - its just those four bolts up top to take it off, am I right? Only had the car three weeks so I am still learning
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Yes, correct, but they are 'nuts'. Remove them and the cover will lift off. Be carefull you don't lose the four little rubber grommets with the steel spacer tube inside them (that the nuts hold down) that locate on the studs sticking up from plenum. Have a close look and you will see what i mean.
    Pablo
    Jan 2007
    Hey Pablo
    Yeah nuts, what did I say, bolts! Sorry, I wrote it at like 1 in the morning so I was probably half asleep!!
    Thanks for the advice about the rubber grommets!
    jafo's Avatar
    jafo is offline lurker since 2003
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    when bleeding the air out with the bleeder screw make sure all the air is out.
    wait till you get a constant stream of fluid coming out not just spitting then tighten the screw and replace cover.
    turn car off check for leaks around hoses as pressure is still in the system do not remove radiator cap when hot under any circumstances.
    ps do not over tighten the engine cover nuts as you will destroy the grommets quarter turn will do once you have tension on the nut
    if all ok happy motoring
    three thing in life are guaranteed
    taxes
    death
    and car repairs
    S.T.K.E's Avatar
    Mar 2009
    Brisbane Northside
    Yeah i do it my way because accessing the thermostate on the super 6 is a ****ing pain in the arse. You can't start the car when you have to remove the throttle body and MAF
    VY II V6
    Dec 2006
    The bleeder on the supercharged v6 is right next to the alternator where the end of the top hose is.
    -Nick.
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    There's 3 bleed screws on the super 6. One on the thermostat housing, one on the coolant pipe (where the top radiator hose joins it) and one on one of the coolant pipes coming out of the front of the LIM.
  1. radiator hose?
    By WhiteVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2007, 09:50 PM
  2. Top Radiator Hose Keeps blowing off ??
    By fourboys in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 03:15 PM
  3. Radiator Hose Clamps..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2005, 08:29 AM
  4. radiator hose
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 08:01 PM
