I have a vx commodore v6 not starting,cranks over but not firing up. We have spark,fuel injection, fuel pressure and fuel volume. The vehicle has had a second hand motor fitted (same problem with both motors). We have tried another comutper,bcm, coils and dfi module. We have given the vehicle another fuel supply but still turns over and not starting up. second hand motor came with it's own sensors.
any ideas .
thanks Dave
Is it automatic?
^^^^^ Thats smarter than what my answer was going to be........
If it was the neutral start switch, it wouldn't crank at all.
it's a five speed manual, the remotes were programmed to bcm and linked to pcm.pcm fitted to another vx and ran fine.
lol, how'd you know I was gonna say it was in gear?!
Anyhow, from what I read it seems as though you replaced the first motor because it was experienceing the same problem?! Which would make me think that it wasn't the key, unless of course the original motor never ran?
How is the battery? If it isn't fully charged it won't start.
So i'm understanding this correctly:
- It has Spark?
- the battery is fully charged?
- Its manual, so neutral switch doesn't apply?
- Theres fuel in the tank?
- The fuel pump is working?
- The fuel is getting into the rails? (lines are attached correctly)
- The starter motor is working?
- All sensors are attached?
- All vacuum lines/hoses are connected?
- key is linked to BCM?
- turns over like its going to start? (cleanly??)
If all that is the case I have no idea!!!!!!
Its not starter / battery / Key because it cranks over.
I would throw a fuel ressure gauge in line with injector rail and see what sort of fuel pressure you have at the injectors. It's unlikely to be the cause, but it will confirm that fuel is ok. Another way to check is to drop the air hoses off tothe throttle body, open the throttle wide and spray aerostart into the plenum while they try and start. if it fires at all, even poorly, you have a fuel problem. Look at lines, injectors, injector trigger connections and the like.
You probably need to make sure your TPS and CAS are hooked up and look okay.
The most likely culprit is Spark. Pull a plug out, Clamp it to some hard area well away from the plughole, insulate it from earth, then have someone try and start it. Use a long screwdriver or something with an insulated handle to bridge between a known good earth - like a strut tower bolt, and the spark plugs outer electrode. Look for strong spark. If it's hard to see, or non existent, you have problems.
If thats the case, look at your coil packs, connections from coil pack to eart and positive and the like. Remove the coils and check the undersides for split cases.
Can only be one of three things, and one of those is a no brainer.
Fuel, air, spark.
battery changed while charging other battery,still the same. Was told first motor has low compression on three cylinders (should still run badly with low compression). Was told to change engine by local holden dealer. Checked fuel lines they are correct, half a tank showing on gauge. tried another fuel source as well (another fuel pump in drum with fresh fuel), dropped off exhaust incase of blocked exhaust system. All sensors and plugs look like they are on correctly.
If the other engine was doing it then it has to be something on the car.
How is the actual ignition switch? Pull it off the back of the barrel and spray it with contact cleaner.
Got to look at things a little more closely. Another fuel source is all well and good but all you have removed fromthe equation is the tank. Could still be fuel lines, rails, poor fuel pressure, frozen injectors, injectors not being triggered, or injectors beingtriggered at the wrng time.
Fuel pressure gauge rules out lines, pressure and rails. Frozen injectors on all 6 is highly unlikely, unless it gott a belly full of filth and every injector is crammed full of crap. Check that each injector has its electrical connection intact to the harness. Check that the harness is connected to the PCM and ECM. If the harness is busted it would be VERY hard to find so cross your fingers that it's something else. If the PCM is functioning - and it would be reporting alarms all over the place if it wasn't, your injectors will probably trigger. It would be pretty hard to make them trigger at the wrong time but it is possible. Again if the PCM and ECM have worked in the past, and remain unchanged, its agood bet that they are ok.
I had rulled out the key / key barrel as it cranks over. Am I missing something there ?
It has to be spark then if it is 100% definatly getting fuel, like Tsunamix said - try the aerostart. If that doesn't work than you know its not fuel causing the issue.
Did you hook up the DFI and coils properly when you changed them?
If the ignition switch wasn't getting a full contact it will crank but one out of the four contacts required to start may not be contacting.
Aah thanks abba. Definitley worth looking at.
Time to look at the electrics then.
Youve ruled out DFI/ECM, Leads, coils, plugs.
Hmm check earth strap to engine block ? The starter could be piking up negative through the harness. Actually it would throw an undervolt alarm if this was the case, so it's not likeley.
That leaves just DFI harness and contacts, ECM/PCM harness and connections (all of which would throw fault codes). All thats left is your ignition circuitry and the Key barrel.
$10 bucks says Abba is right.
