Results 1 to 10 of 10
Thread: VX Bad idle
    slipstream001 is offline -=Slipstream=-
    VR Senator II
    Jan 2007
    Werribee, Victoria
    Exclamation VX Bad idle
    hi all just after some advice, had a small amount of water inside the rocker covers on a VX acclaim v6, so stripped down the heads and intake, while initially we were going to replace the engine we decided to try and replace the gaskets and see how we went, the gaskets have all been replaced and the car is now running again and while driving its smooth with no issues but at idle either in park/neutral or drive it idles that bad the whole block shakes. i've no idea as the plugs and leads have been replaced, the intake was going to be taken off again and thoroughly cleaned so atm its rather dirty. i'm wondering if anyone has any ideas on what the problem may be ?
    also when the car is in drive and you turn the steering the car almost stalls
    any ideas would be great as i've no idea anymore am thinking about replacing the timing chain as the car has done 250000 k's and haven't a clue if its been done,
    VT 2
    Nov 2008
    The stall on steering turn is a charateristic of bad idle - it doesnt have enough grunt at idle to power the power steering pump and run..
    Im not sure on this one. Im leaning towards one of your sensors being stuffed. It's unusual for coils and leads to be at fault at idle, more often they short as impedance across the spark arc grows - Ie greater revs.
    Check Cam angle Sensor and Throttle [position sensor.....
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Probably not it but its only a 1 minute check. Check the purge valve vacuum hose on the bottom on the throttle body. Mines come of twice and my parents has come off before as well, very common. Basically means idle air isn't going past the air flow meter.
    Ronald Reagan (1986)
    VR Senator II
    Jan 2007
    Werribee, Victoria
    cool i'll have a look asap, also where the water hose connects to the metal pipe for the heater tap its leaking a heap of water when the cars revving hard 3k+ and also the water that was in the radiator is white... so not sure about that one either we're looking around for another engine now too
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by acarmody View Post
    That'd be my guess too. Get some superglue onto the pipe and hold the hose on there for a few seconds. Will stop it falling off again.
    VR Senator II
    Jan 2007
    Werribee, Victoria
    the vacuum hose is on, still not sure as to what the problem is, the white water in the radiator is a worry tho and i took the oil cap off and there's once again the tell tale sign that there's water leaking somewhere because it's white...so guessing the heads are cracked somewhere :-(
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    When you have the idle problem. Right off the bat as you turn the key or as the car has warmed up?
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    VX Berlina
    Apr 2007
    Quote Originally Posted by slipstream001 View Post
    Not necessarily cracked, might just be a worn gasket.
    vx s pack II
    Jan 2010
    aLKIDA
    I have seen cars at work that have cracked heads,blown head gaskets that idle very rough.
    So this could be the reason for your rough idle.
    If engine mounts are worn the engine will shake aswell. But i dont think thats the problem here.
    Also if there is a leak in the air intake duct this also makes the car idle rough.
    There are lots of things that can make a car idle rough look into it and do as much tests as you can do.
    VR Senator II
    Jan 2007
    Werribee, Victoria
    well the head gaskets have been replaced just a day ago, we've sourced a reco VY engine, can anyone tell me does the wiring loom from a VY connect to the 2001 VX or will i need to remove the VX wiring loom ?
  1. idle problems. won't sit at a constant idle.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 07:59 PM
  2. VR won't idle
    By Rupert in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2009, 01:00 PM
  3. Getting Hot @ idle?
    By Macca177 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2007, 08:03 PM
  4. vp ss bad idle
    By drewboy in forum General
    Last Post: 01-11-2005, 05:58 PM
  5. VP S2 Idle
    By raffie87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2005, 08:25 AM
