Results 1 to 18 of 18
Thread: Installing springs in a VXII...?
    VX Acclaim II
    Feb 2009
    Default Installing springs in a VXII...?
    So i bought some Low King springs for the VXII and decided to install them myself.
    Looked pretty simple, so I started on the rears. Jacked it up, put it on stands, undid the shocker, also undid the panard rod, put the spring compressors on (not easy as there's bugger all room) but couldn't compress the spring even close to getting it out.
    So i undid the swaybar linkage, then jacked up the swingarm to compress the spring, put the spring compressors on and let the swingarm down again. It was slightly more compressed but still not even close to coming out. The only thing Left I can think of is to undo a CV joint to disconnect the axle, and hopefully the swingarm will drop enough to get it out. Is that right? is there no other way to get the stock springs out of a VXII?
    Anyway, didn't have the tools to take the axle off so put it back together and started on the fronts. No worries, pulled the struts out, springs off, new springs on and reinstalled the struts. On the second one though, the ballrace in the top of the strut came out and ball bearings went everywhere! So i tried to find them all, clean the dirt off them and put them back in. It seems ok although i think there's 1 or 2 balls missing and it sounds slightly dirty in there! RRR...
    Anyway the fronts back together and drives ok, occasionally makes some creaking noises at very slow speed though. I read somewhere you have to be sure to align the tops of the struts into the strut tower correctly... it just seemed to go straight in for me, is there a process i missed? Wondering if thats whats causing the creaking noise?
    VX Acclaim II
    Feb 2009
    By the way the noise seems to be coming from the passenger side front strut, not the one i spilt the ball race from! So it doesn't seem to be the bearing
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    did you only put lowered springs in or shorter strust as well?
    ive been told when lowering a (vx) you will have to put a 4 point camber kit in it to. just check! i havent got around to doing this yet! so good luck
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VX Acclaim II
    Feb 2009
    Well only the fronts are in so far!
    But from what I read you only need shorter shockers on the rear with superlows or lower. Lows should be ok apparently.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    VX Acclaim II
    Feb 2009
    Fair enough, thats pretty damn low though! Good luck.
    Has anyone changed the springs before?
    VT Series 1 V6
    Jan 2008
    Hi Mate,
    I have changed all 4 springs in my VT. On the rears I had to disconnect the drive shaft CV at the wheel end, the sway bar blocked it from dropping all the way but it was enough to get the springs out/in with some gentle caressing.
    The fronts were straight forward as you mentioned. To be honest though mate, I would have bought a new set of top bearings, particularly if you've lost a few. Make sure to also check all the other components, sway bar links, caster bushings, D rubbers etc. Also, how old are your struts? have they been replaced before? Perhaps lower springs are putting some new stresses on older items and the groan you mention is their protest song. Also a wheel alignment is a must.
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Have you taken the handbrake off when trying to change the rears? The handbrake won't let the cradle go to its lowest point if its on.
    Watched my mate with his HSV VQ trying to get his springs out for ages, before I stopped laughing and asked about the handbrake.
    BXHD Guest
    yeah i was going to say take the handbrake off.. if that hasnt already been tried
    VX Acclaim II
    Feb 2009
    Dammit! Didn't realise the handbrake would do that, and yes it was on the whole time. It was booked in to get the wheel alignment today, so I just got them t put the springs in the back, $60 wasn't too bad I thought. Also told the workshop to check over the struts, make sure I'd tightened everything properly.
    The struts and shocks are all original as far as I can tell, the car has 95000k on it now. So I guess that could be it? I figure I'll look at new bearings for the struts but it should be rebuildable anyway right?
    BXHD Guest
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Sure does. I nearly shat a brick when the guys at Bob Jane showed me. I thought my car nearly slipped of the hydraulic jack.
    Ronald Reagan (1986)
    VX Acclaim II
    Feb 2009
    Ahh spewing when the answer is so simple! Oh well.
    Its done now, quite happy with the height too, much neater but will be able to tow no worries and the ride is still comfy!
    Aany clues on the bearing thing?
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    The bearing fell to pieces, meaning it is stuffed, buy a new one, do both sides as well as your strut mounts.
    The way to tell if your strut mounts are gone is, the sleeve (where the strut shaft goes through) should be below the level of the outer part of the strut mount, if it is above, then it is worn and needs replacing. (this should definitely be done if you can see cracks forming around the sleeve when you flex it with a screw driver.
    As for the camber kit, you need a 2 point kit.
    I have a 4 point kit and just added the toe adjusters, like in your VX II and was told by pedders that a 4 point kit is an overkill and i need to make it a 2 point kit so that the bushes don't wear too quickly.
    The camber kit will adjust camber, while the toe adjusters will adjust... well you know.
  15. #15
    VX Acclaim II
    Feb 2009
    Yeah you're right, I'll change the bearings when i get round to it.
    This sleeve you're talking about - is it the soft rubbery sort of cone shaped thing? It seemed to be alright if so...
    And how much is a 2 point camber kit worth? Whats the different between that and a four point kit?
  16. #16
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Holden Commodore VR-VT,VX-VZ Strut Mount & Bearing Kit - eBay, Other, Car Parts, Accessories, Cars, Bikes, Boats. (end time 21-Feb-10 22:08:30 AEDST)
    if you are going to do it, buy this, I wish I got mine this cheap when I did it. From Holden or any other retailer, you are looking at $150+. One thing to look at is that they superseeded the bearing due to these premature failure problems. The old one has 'Germany' engraved in it, while the new one does not. I don't know the real difference between the two, but if you look into it, they have different part numbers. If you aren't worried about it, just go for these.
    As for the mounts, you can see that inner section, then a smooth gap before the outer part, that's what I'm talking about. If it's worn, this inner section will be above the level of the outer part. The outer part doesn't wear, by that I mean those rectangular notches won't wear.
  17. #17
    vx/vp berlina
    Jun 2009
    wollongong
    hahaha same thing happened to me, but i relised straight away that the handbrake was on when my springs wouldnt come out
  18. #18
    Nanos's Avatar
    Nanos is offline Not a Mod
    VXII LS1 Berlina Wagon
    Aug 2007
    Frankston
    im a little confused because the VX is IRS in the rear so there is no panhard rod. this was only for the solid axles found in vs and older.
    when i did mine i just got a big bar and pushed the control arm down. springs then popped out, from memory on wide side i disconnected the drive shaft ws no special tools needed just unbolts from the diff.
    creak could be anything, if you have used stock sstruts then that could be issue, coul;d be a worn bush that is more aobvious now ause it is working more, also fron tsprings have a left and right did you make sure you put them on the correct side?
  1. Installing new springs
    By sprocket in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-08-2009, 05:47 PM
  2. VXII S/C - What should I mod first
    By vagure5 in forum V6 Development And Modification
    Last Post: 28-05-2006, 07:48 PM
  3. vxI ss vs. vxII ss
    By trepaul in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2005, 01:21 PM
  4. installing lowered springs
    By Tony2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2004, 08:25 PM
  5. installing rear shocks/springs
    By adsVN in forum General
    Last Post: 26-04-2004, 01:33 PM
