Results 1 to 2 of 2
Thread: Removing foam air filter on VT 5L
    VS Acclaim S2
    Aug 2009
    Liverpool
    Default Removing foam air filter on VT 5L
    Hi, I've got a VT 5l that came with a Foam filter. I'd like to remove it and put the original airbox back in with a Lukey panel filter I've bought. I've got all the parts i should need, bought a new airbox and CAI. all I think i need to do now is remove the foam filter and put the new parts in and connect it all up. however when i take a look i can see a wire and sensor that leads into the foam filter and looks as though it was done by cutting into an existing sensor wire and attaching itself to it. I'd like to know if this is a factory sensor wire or a dodgy one, and how this will affect putting the original airbox back in. I've included a picture with white circles around the part I'm talking about and two more pictures giving more of an overall idea of where it is and would appreciate any help i can get in identifying this wire along with any other advice for completing the job. Thanks.
    Attached Thumbnails Attached Thumbnails Removing foam air filter on VT 5L-1.jpg   Removing foam air filter on VT 5L-2.jpg   Removing foam air filter on VT 5L-3.jpg
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    airflow sensor i think just re-do all you OEM parts and if it fits (mabe it need a longer wire due to a different spot) replace it. P.s that is one dodgy possibly restricitve set up.
  1. removing vn oil filter
    By rawsonn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2008, 06:06 PM
  2. Removing Oil Filter Tip
    By pro_gmh in forum General
    Last Post: 16-08-2006, 09:05 PM
  3. Removing the fuel filter on a VX V6
    By smiffs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 08:15 AM
  4. Removing Oil Filter from Corrolla
    By Shounak in forum General
    Last Post: 19-10-2005, 02:21 AM
  5. removing filter from injector
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 01:19 PM
