hey ive got a 98 vt s pack and want to put super lows in it but have 15" stockies on the back and the alloy 16s on front just wondering if anyone has seen 1 and how much clearance there would be with the bodykit dont really want to much scrape
hey mate,
ive gotta set of ultralows in the backend of my vt S pack and with the standard 16" alloys on the back i can just fit a coke can laying down under the sideskirts.
the clearance between the guard and the tyres is just enough to get your hand in between.
so im guessing that with superlows ull have just a bit more than that.
hope this helps.
cheers just what i was looking for and also do ur back tyres sit in on an angle think i might need a camber kit?
My VX wheels don't sit on an angle with Super Super Lows.. But its reasonably common for people to whinge about the rear tyres wearing down the middle on VXs so perhaps the last owner put a camber kit in before I bought (and lowered) it
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
yer my back tyres do sit on a slight angle. just bought myself a camber kit last week, so now i just gotta get round to fitting it and getting an allignment done.
ebay is a good place to look for them, you can sometimes find some cheap ones on there.
Hello all!
The fuel gauge in my VU series 2 SS ute reads empty all the time even when the tank is full. A couple of months ago a scan tool used to check how the engine was running. By a friend....
Somehow?? all the gauges failed to work after the scan tool was removed. The speedo, fuel gauge, tacho & engine temp gauge did not work at all. Another scan tool was plugged in and I got the engine temp, tacho & speedo working. However the speedo would read full deflection to 220km/h when I was actually travelling at about 40km/h.
Then another scan tool with "holden software" was plugged in and all gauges worked correctly except for the fuel gauge,, which showed empty and the fuel warning light would always be on and the airbag warning light would always be on.
A mechanic managed to reset the airbag light and fix that. But they could not fix the fuel gauge. Telling me that they reckon the fuel sender was stuffed.
When I was returning the car back to person who created this mess, the ute broke down, requiring a tow truck ride back to the nearest Holden dealer. Where they have now informed me that the fuel pump is stuffed and some ECU relay has burnt out.
The cost to repair is over $900.00!! --- Is it possible that when the modules in the car were interrogated by the scan tool, that some setting/s where changed stuffing the whole thing up?
I find it to much of a co-incidence that the fuel gauge sender/fuel pump unit fails after a scan tool was used on the car. Has anybody had this or similar experience, as I believe I'm paying for a new pump when the fault is within a module somewhere... NOT HAPPY JAN!!
