Results 1 to 11 of 11
Thread: VX Cruise Control Holden Kit instructions
    VT Exec S2, Monaro CV8
    Mar 2009
    Default VX Cruise Control Holden Kit instructions
    About a year ago, I bought a geniune VX , cruise control kit for my VT II , have fitted the twist type indicator stalk and boughty matching wiper stalk when I first got the kit.. When i dragged it out of storage recently to finish the install, instructions have disappeared.... Was wondering if anyone out there have a copy (scan or PDF or similar) of the instruction pages they could forward to me? I have found similar threads in search, but none appear to have the attachments still visible. Thanks
    VT HBD LS1, VL calais project
    Nov 2009
    SE bris
    hey mate have u already got the wiring plug in the engine bay(its a orange plug) it will be right near where the c/c unit bolts in
    Mar 2009
    It doesnt have the harness tucked under. The harness is part of the kit - relatively straight forward, but couple of pins need to be inserted in existind plugs etc so instructions seem essential
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    Funny, our S2 VT Exec has the harness hanging from the drivers side shock tower - go check again.
    I added cruise control to ours (Police Pack) and it was all just plug and play.
    Didnt need to add different looms or anything.
    Added the module, added the cable to the T.B
    changed the stalks and added the brake switch and it wall worked - no issues and was fitted in around 20 minutes.
    Mar 2009
    Hi- I definately did check again - right up to removing plastic cable tray and lifting fusebox - no connector! It seems from reading similar threads, that some were fitted with it, others weren't - luck of the draaw - maybe late series II had it........
    Anyways - I'll have to keep on searching, (or hoping someone has set of instructions....) - I'll bet holden will not be able to photocopy a set..... LOL
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by Brissie_VT View Post
    You're in luck.I've got it.Let me dig'em out then i'll scan and post'em 4 you.BTW,is it man. or auto?This is for man.
    Mar 2009
    Smile
    Cheers mate - yoiu're a legend
    It is auto, but the instructioins I got with my kit covered both manual and auto
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Some Commodores came with wiring looms to support things like power windows, cruise control, climate control and higher level BCMs already installed and others didn't.
    Whether they just ran out of the lower end wiring and put the better stuff in some cars, who knows?
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Quote Originally Posted by Mick1988 View Post
    Yeah that's it, they discovered this during the series 1 due to fleet sales, so some were uprgraded, in the series 2 i think all if not most models had the higer than lowest level wiring loom
    Mar 2009
    Angry
    Bummer.......
    I must have one of the few that had a low level wiring loom
    VY Exec & VZ Calais
    Mar 2010
    Did anybody end up getting these instructions?
    I'm really desparatley after some instructions for my VY (most shold e the same really.)
    There is NO existing wiring in my car, but I have engine and cabin loom, actuator, throttle cable and brake switch.
    95% is straightforward, it is just a patch loom and plugs into existing BCM/PCM but there are two connectors and 3 bare wire I don't know where they go.
    Everything is in apart from these and few wires and it won't work until I know where these go.
    VTS5 said he has them. If you do, may I please get them as well. Thanks in advance mate.
  1. Vt Cruise fitting instructions
    By tassie5 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2011, 04:16 PM
  2. VY Holden workshop manual for cruise control
    By J.T in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-02-2011, 10:24 PM
  3. Holden Calais 2003 VY Cruise Control Problems
    By darkphat in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-01-2010, 09:29 PM
  4. climate control instructions,
    By Gus58 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2009, 11:02 PM
  5. Cruise control instructions for vx
    By chippy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2006, 05:25 PM
