Results 1 to 8 of 8
Thread: abs & trac light comming on????
    99 VT Sedan
    Feb 2010
    Exclamation abs & trac light comming on????
    When driving the abs and trac off lights come on
    Anyone know how to fix this????
    2000 vx supercharged
    Feb 2010
    abs module might be able to find 1 at the wreckers with trac control but if not your prob looking at about $300-$400
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by tatty View Post
    I was talking to someone that has same problem they put new abs module after fitted made no differance
    Could you think of anything that would cause this???
    I have been to auto elec they found no error codes cause the light wasn't on that that time
    I have change crank & cam angle sensor
    Could you think of any sensors that fail in these cars??
    Feb 2010
    how often is it happening
    take it back and get the auto elec to plug his comp in again but i am 100% its the abs
    99 VT Sedan
    Feb 2010
    only happens when going over a bump in the road
    So maybe loose wire faulty sensor???
    i havn't been to auto elec when light was on ...
    Need to wait till lights go on then need to get it checked again
    Can you think of any sensors that could be causeing this??
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by mummbles View Post
    yup, it was the ABS in mine when those lights lit up for me.
    just by going what someone els said they were having same problem they changed abs and made to differance
    Did you change any sensors /fixed and wiring when you changed abs??
    VX Acclaim
    Feb 2010
    Orange NSW
    For me this happen just after installing LED light globes for Brake lights without using the resistors supplied.
    Added resistors to wiring. problem fixed.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Help Low trac light comes on!!!!!
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2008, 10:46 PM
  3. dash light not comming on
    By BURK_POP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2007, 03:44 PM
  4. Trac & Power buttons lback light
    By BOGANV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2006, 10:16 PM
  5. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
