Results 1 to 6 of 6
Thread: VT Jumping Violently when foot down from 0
    VT Calais V6
    Mar 2009
    Default VT Jumping Violently when foot down from 0
    Hi Guys,
    Have a bit of a dilemma, My VT calais (v6 3.8ltr Ecotec) is having abit of an issue accelerating at low revs?
    It seems that if i roll off and drive like a sane person and slowly start to accelerate its fine.
    But if i put my foot down even half way, (from stationary) say at a stop sign or something, it jumps and has no guts at all (not that the ecotec ever did have guts..)
    Now this has happened before and my mechanic replaced the spark plug leads (12 months ago), so i followed suit and replaced my spark plugs about a month ago, and only replaced the leads this afternoon.
    It hasn't fixed it though! does anyone have any more ideas as what could be causing this.
    Thanks,
    Jamie
    VT Series 1 V6
    Jan 2008
    I know you replaced your plugs, but might be worth checking them again to make sure they didn't crack when being tightened (this has happened to me). Also make sure the leads are connected in the correct order.
    If plugs/leads are OK, the next thing I would check would be the fuel system. Get your mechanic to test the fuel pressure, it's possible your fuel pump is on the way out or your injectors could be blocked.
    VT Calais V6
    Mar 2009
    brand new fuel pump about 2 months ago T_T, and put injector cleaner in for the sake of it when the issue started, and yeah, i'll throw some more spark plugs at it
    VT Series 1 V6
    Jan 2008
    Hi mate,
    I didn't mean go an buy new plugs off the bat. Check the new ones you just put in as it only takes a little bit of over tightening to crack the ceramic part of the plugs which then leads to the problem you encountered.
    When the same happened to me, I found one of my leads had gone, so I replaced the plugs and leads only to find the same problem occurring. I rechecked the plugs and found I had cracked one.
    VT SUPERCHARGED
    Oct 2006
    VT 2
    Nov 2008
    Busted engine mount.
  1. Jumping off a fuse?
    By Bobski in forum Electrical Wiring / Questions
    Last Post: 19-12-2009, 10:51 AM
  2. car shakes violently when braking
    By 98 vt olympic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 01:24 PM
  3. jumping around
    By limited_edition_vl in forum General
    Last Post: 16-02-2007, 07:15 PM
  4. idle jumping around.
    By dlzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2006, 12:41 AM
  5. VT missing violently
    By jbean in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2006, 03:15 PM
