hey guys bought a vt ss 160,000kms 5,000 week ago got a noise a day ago like a ticking noise im a diesel mech and airplane techo. so not great with petrol , thought it was lifters being lazy did the engine flush new oil nulon lifter eze , and caboom! noise become loud so shut off pulled off rockers and inlet manifold retainer plate tangs broke (x 3) roller lifter x1 roller snapped and then took cam out it marked but no lobe missing,
question
where do i find a reatiner plate or should i weld tangs back on
what lifters do people recommend and price about?
should i just regrind cam or get a new one
hopefully someone can help.
Can cam places regrind original cams to get a better profile if damage is not t bad Camtech is just down road that's all
1. Wrecking yard
2. Comp Cams lifters are supposedly pretty good
3. I would definitely go new camshaft
Ronald Reagan (1986)
I beleive the V6 lifters are the same part (different part number and cheaper but the same part) the plate those are rare as so you might have to repair that
I thought the 5L lifters were the same but the LS1s used a different part. VT SS could be either engine.
i just cam tech they said i can regrind the cam 275
and gave price for johnson lifters 265
said i had to get new pushrods as the grind takes .25 off base circle want 270 for new pushrods
does this sound right thought?
i might ring wade camshafts as they where what dad had in in his racecar when he started HQ racing in australia
the retainer plate is a problem i saw one on a website for 600 i wonder if u can weld spring steel and put lugs back on
two questions , how do u check preload on lifter pushrod assembly and i took dizzy out when i removed the cam but did not mark it is it easy to put back in right spot
i took out the cam by using GREENFOAMS GUIDE good work big guy just had trouble undoing balancer bolt
thanks for ur replys as im flying blind on petrol engines.
What are the specs on this "275" cam.
I don't know who Johnson's brand are but you can normally pick up a set of lifters in near any brand for about $300. See if you can get Comp Cam lifters, supposed to be a damn good brand.
The cam will generally have a 0.025" smaller base circle, this can usually be picked up by the lifters.
Can't help you with dizzy, but here is an article on checking preload.
CraneCams
EDIT: Oh and I just bought new rods for my V6, generally found to be $15 each here is Oz, of about $6 each from USA, for same item. So if you got a bit over a week to spare for postage then it will work out considerably cheaper. Or I paid $85 for express international postage because I needed them straight away. But you can't measure the pushrods until you have installed new lifters and cam. If you have managed to kill a lifter and camshaft then likely you have damaged/bent a pushrod or two as well.
they said they where going to regrind my original camshaft just above standard grind it will cost 275 to do it
pushrods look ok but dude at camtech said if he regrinds cam it will take .25 off base circle so will need bigger pushrods true/false?
.25" is a hell of a lot of grinding. If its too just about standard I'm sure he meant 0.025" but by all means just ring/see him and find out. If its just 0.025" then you should be able to get away with standard pushrods and just torque the lifters down just a little bit more. But to do it properly you will need to fit the cam and lifters and measure the preload. I wouldn't buy the rods yet, fit everything else and then find out. If it turns out you don't need them then sweet you saved some cash, if you do need them then your no worse of then before.
Just make sure your current pushrods are perfectly straight, they are under a lot of stress when you rev the car and a tiny bend will ensure you have to pull the engine apart again and replace more broken stuff.
thanks guys for advice the retaining plate is the issue found one on ebay $250 but bidding had closed cam i will get re ground and get some lifters and then see if i need pushrods
if i go for a new cam what is a good slightly above standard cam
wade
camtech
You still haven't said whether you have a 5L or LS1.
I don't think the LS1 even has those parts that broke?, assuming we are talking about a roller VT 5litre here. Camtech are a good company as are Wade both will be able to sort you out with a good small cam. You can fix the smaller base circle on the cam with either pushrods or shims. But a new cam shouldn't be anymore expensive and saves you the trouble. Johnson lifters are supposed to be the best you can get but I'm not sure they are made anymore or not made in the states like they used to be. Holden probably would have used them OEM in the motors in the first place
