Results 1 to 8 of 8
Thread: VT V6 head bolts
    Vy S V8,VT V6, Rodeo 3.5 V6 4wd
    Aug 2008
    Default VT V6 head bolts
    Hello all, can anyone advise if I need to replace the cyl head bolts on a VT with 180k on that has been overheated?
    The heads are off and have been machined ready to go back on, gasket packet says replace head bolts? any clues?
    Jonesy VT
    VT SUPERCHARGED
    Oct 2006
    vt/vx ls1
    Jul 2009
    from wat i have read so far it seems holden uses single 'use' bolts. must be cheaper or something.. and i think if u use the old ones u run the risk of breaking the bolt off in your block when u torque them up to spec... i have to get ls1 head gaskets n bolts myself for a cam n lifter install.. im acctually searching the forums now to see if i could find how much gm gaskets and bolts are.. otherwise arp bolts seem to get used a fair bit by everyone-so i have noticed.. think there bit dearer though.. gud luck with it..
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    replace them...why ? because one person pointed out there use once deal...
    secondly...heads that warp...and do so from overheat.....do 2 things
    1) warp the head surface
    2) damage the thread on the bolt or in the head.
    when they do damage the head sometimes that means you need to halicoil the thread on the block..
    or brass bush sleeve them...
    means they have pulled part of the head thread out when removed and now you need to put metal back..
    the only way is drill the hole to the closest size and use helicoils...or drill bigger if you can and thread brass into the head....like little cyclnders...then rethread to standard head bolts...
    allot of places wont helicoil or brass thread...cause they are lazy!
    so check your thread on the bolts....you pulled out
    and dry run thread the old bolts back in the heads..using clean oil...and make sure
    they thread perfect...and easy.... and remove any dirt of crap from inside them..
    machine shops sometimes forget..to do so...
    now knowing yours are clean and good ...go to holden and get new ones..fit them..then throw the others in the bin..
    showbags's Avatar
    showbags is online now Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    these are known as flex bolts. as the name says they flex. you will never be able to torque the old bolts EVER. for the sake of $60, throw them in the bin.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I would change them. Cheaper to put new bolts in, then have to take the heads off later.
    Ronald Reagan (1986)
    99 VT Sedan
    Feb 2010
    I plan to replacing rocket cover gasket
    ARe flex bolts used there also??
    Sould in buy new bolts??
    holden91 is offline Kickin it sideways
    Vs series 3 ute, ve berlina and a eh wagon
    Mar 2010
    rockhampton queensland
    rocket cover gaskets not so much, i replaced the works on mine when i did the head gasket. i got a gasket kit and replaced the works gaskets and bolts to be safe then sorry, also the best gasket silicon ive ever seen as ive done a few is copper spary in a pressure pack.
  1. [VIC] WTB- 253 Head bolts & Pushrods
    By lil_mickey in forum Swap / Wanted to Buy / Trade
    Last Post: 15-11-2009, 01:40 AM
  2. V6 3.8 head bolts sequence
    By AlpineRaven in forum General
    Last Post: 14-07-2009, 08:42 PM
  3. rb30 head bolts?
    By ImAHoon! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-12-2008, 08:10 AM
  4. Head bolts for a 202
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-02-2007, 09:08 AM
  5. Head Bolts Torque
    By Matty081 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-10-2005, 02:51 PM
