Results 1 to 8 of 8
Thread: TPS issue driving me mad...
    VT Olympic
    Feb 2010
    Default TPS issue driving me mad...
    Hi y'all,
    I've got a drama with my VT Olympic that is driving me completely mad.
    The gear changes are all off pretty much all the time - sometimes it will stick in a gear when it should be changing or it will change down when it shouldn't.
    It's also randomly throwing a TPS error and lighting up the powertrain light, at which point it makes a nasty 'clonk' every time it changes gear and has to be stopped and turned off to reset. After this it will behave for a while again.
    I've had it into the mechanics and auto elec a stack of times now and they still haven't managed to fix it.
    So far it's had:
    1. new TPS (holden genuine)
    2. All new wiring form TPS to computer
    3. Computer tested ok.
    Wondering if anyone else out there has had the same issues and discovered the cause?
    Any help at all would really be appreciated!
    Cheers!
    VY SII HBD Calais L67
    Dec 2006
    The coolant temp sender and TPS share the same earth. Might be another avenue to follow. You haven't got a ported throttle body by any chance do you?
    VYII Calais L67
    VT Olympic
    Feb 2010
    Thanks for the reply, the autoelec checked the earth circuit and replaced all that wiring too just to be sure.
    Dunno about the the ported throttle body, I'm a bit of a space cadet really. What would it mean if I do?
    VT wagon
    Nov 2009
    Have you reset the ECU after you replaced the TPS?
    And what did you use to test the ECU?
    VT Olympic
    Feb 2010
    I didn't do the replacement, so not sure if the mechanics did reset it, will check with them.
    Cheers!
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    some of the holden throttlebodys require a plastic adaptor on the end of the butterfly shaft where the tps goes over it if its fallen off the tps reads funny and spits codes etc
    vp calais 5.0
    Sep 2011
    trentham vic
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Check out the diagram for the drive adapter.
    Attached Thumbnails Attached Thumbnails TPS issue driving me mad...-v8-tps-replacement.jpg
  1. driving to qld
    By az_sv6 in forum General Discussion
    Last Post: 10-09-2009, 09:02 PM
  2. sms driving ad
    By Jecs in forum The Pub
    Last Post: 30-08-2009, 08:25 AM
  3. Driving a VE
    By tigerpm7 in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-12-2008, 03:37 PM
  4. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  5. driving me mad
    By Northern_Union in forum Electrical Wiring / Questions
    Last Post: 02-09-2007, 01:17 PM
Tags for this Thread
