gday,
im thinking of buying a vt with 130 000kms, rego till may good condition for 3700 etc but the power steering isnt working at all. its extremely difficult to turn at low speeds to a point of frustration. what could the problem be and how much would it cost to fix?.
im thinking the fluid is gone or the pump is leaking but im not very experienced in that area
Pump and or Rack
if this problem turns out to be to do with the rack, or has ruined it in the progress, you can pick up a reco rack for $300 - $400.
If you are keen to diy, you can get a pump seal kit for around $10, unless the whole pump is shagged (bearings etc._
maybe the ps belt has just slipped off it happend to me before and it was a workout every day. although i dont know if the vt has a independant ps belt??
Holmart have pumps reco with no change over for about $90. I seem to recall seeing brand new racks for not much nmore than a reco one. I'd make sure the system had enough fluid and replace the pump first making sure it was flushed first to remove any contamination etc.
