hi guys, i hope some one can help me. situation is i have a vt v6 calais which has developed a bad hesitation(like it's runnig out of fuel) when accelorating. it started out as a flat spot at full throttle at about 4000rpm but has gradualy got worse. now it's all through the rev range apart from light throttle. also if it sits there idling the revs flare to about 1400rpm and the drops back to 1000rpm(too high). when it does this it sets error code 36, which indicates a vacuum leak( which i cannot find by the way). this is what i have done so far - replaced fuel filter and cleaned tank, fuel pump pressure and delivery seems to be o.k.replaced i.a.c valve and cleaned throttle body, checked vacuum hoses, replaced tps sensor, replaced inlet plenumn gaskets( both bottom cover and throttle body). if i diconnect the battery to reset computer it runs o.k. for about 30-40kms and then the revs flare up again and it set code 36 again. this is the only code it sets by the way. please help if you can
i had a similar problem replaced leads plugs and battery went fine after that!
already done that. the first thing i tried.
could be a bung fuel injector?
when was the last time they were replaced or checked?
There are 2 types of pedestrians, the quick and the dead
Check out my ride here....
http://forums.justcommodores.com.au/...rlina-ls1.html
i reckon you have a bung injector seal.
thanx guys, 6x reco injectors-$120 & 2xnew oxygen sensors-$100 = all sorted me a very happy camper.
