Results 1 to 7 of 7
Thread: VT air bag light
    VT Acclaim S/W 1999 V6 & VX 2002 x police sedan
    Feb 2010
    south/ eastern qld
    Default VT air bag light
    the other day I changed my Ing barrel.( in mine I had to change the hole steer system) plus my blink and flash arm. to fix lights cutting out when you flash lights. changing the above fixed my problems. but now my air bag light and a tone comes on I lined the clock up as stated on clock, but it back together and still warning light and tone still comes on even got another clock still the same. my question is does any one know whats going on, do I have to get the blood suckers to reset my computer!!!!
    all help wellcomed.
    Brian.
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    dunno exactly but you might have to get a dealer to put the tech2 on to reset it. a few vt's i have had the airbag light just stays on,even if i havent touched anything. somewhere i read there is a fault with these,maybe yours finally decided it supposed to be faulty & comes on. other thing is theres a plug under the seat as well,if this plug is loose or has dirty connections etc it has be known to cause the airbag light to come on. will have a look through my techline updates to see if i can find something for you. i never bothered before cause it didnt worry me
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by bnghardy View Post
    all help wellcomed.
    Brian.
    This happened to me when i stem cleaned the carpet
    I just took to auto elec and they deleted the error the light hasn't been on since
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Unplugging the clock spring will trigger the warning light. You will need a Tech2 to reset it.
    Whenever working on the electrics, disconnect the battery to avoid this problem.
    MY RIDE
    Feb 2010
    south/ eastern qld
    did all that disconnect the batt first . always trying my best in these things. i'm getting to old and cars are getting to newer. looks like I have to spend more money to fix this problem!!!!!!!!!
    99 VT Sedan
    Feb 2010
    I just took to auto elec they deleted error code (air bag light)
    It only cost $50 takes them a couple minutes
    Feb 2010
    south/ eastern qld
    thanks for that
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  3. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  4. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
