Results 1 to 12 of 12
Thread: VX - Battery Light
    Ant
    Ant is offline
    Apr 2004
    Default VX - Battery Light
    Hi All,
    Hoping that you can provide some advice.
    I have a VX SS, and the battery light has come on.
    Popped in battery world to check what the go was and the guy used a multimeter to check voltage - advisd the alternator wasnt charging.
    I've noticed a few posts on here with people fixing bushes etc. My question is, before i fork out for a new alternator (cheapest i have found was 400$) what can I do to be sure it is the alternator.
    Volts:
    Car in acc mode: 11.6/7
    Starting drops to around 8, then sits at 11.6/7
    vx berlina wagon 5.7
    Feb 2010
    Bendigo, VIC
    start the car put a multimeter on the battery it should say around 14v if it doesn't your alternator is stuffed, should be able to get a reco for cheaper
    Ant
    Ant is offline
    Apr 2004
    Quote Originally Posted by jay_wr8 View Post
    Doesnt get near 14v when running.
    Best spot to get a reco alternator?
    vx supercharged
    Feb 2009
    Feb 2010
    Bendigo, VIC
    yea auto elec, they sometimes have a spare ready to go so you just give em yours and cash and take the reco
    Ant
    Ant is offline
    Apr 2004
    So I puled it apart, and found the termianl on the back of the alternator was dirty and damaged.
    Replaced it, and voila.
    xCalliba's Avatar
    xCalliba is offline EPICVN
    VT 9C1 5.0L & VN 'S' Pack project
    Mar 2008
    Kyabram, VIC
    ant, was the battery light cumming on randomly, or came on and stayed on?
    i ask because the batt light in my VT comes on randomly for anywhere between 5mins and upwards and turns off eventually. perhaps the terminals on my alternator could be shoddy??
    Ant
    Ant is offline
    Apr 2004
    Came on all of a sudden, I'd pull it out and check the terminals before you invest in a new alternator.
    xCalliba's Avatar
    Mar 2008
    Kyabram, VIC
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    the positive terminal on the alternator has a habit of coming loose and frying alternators...i've seen a few vt/x's do this. just check if the nut securing the power wire on the alternator is loose. (including my own)
    and its not always the alternator that causes the battery light it can be the regulator at the back (the black box) to check remove the regulator and if the spring loaded brushes are less then say 5-8mm replace as the new ones are a good 15-20mm long.
    vx s pack II
    Jan 2010
    aLKIDA
    Hey mate.
    I am guessing you have the 120amp alternator in your SS
    If you have a V8 then the regulator would be inside the alternator and to replace it you will need to open up the alternator. On the ecotec V6 the regulator is mounted on the out side of the alternator.
    If the main battery connection on the alternator to the battery is good check for voltage drop from the alternator to the battery. (Should be around 0.5 no voltage drop)
    If this is ok change the alternator.
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    Quote Originally Posted by PRAVX II S View Post
    thanks for the correction i totally misread the SS part haha
  1. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  2. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  3. vp battery light?
    By 93vp1car in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2009, 02:03 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. battery light on & orange light on
    By smokey.29 in forum Electrical Wiring / Questions
    Last Post: 12-02-2007, 06:16 PM
