Results 1 to 17 of 17
Thread: VX Aircompressor - Dead.. Will a VZ aircompressor fit/work?
    VX Berlina S2
    Feb 2010
    Default VX Aircompressor - Dead.. Will a VZ aircompressor fit/work?
    Hey guys.
    Sorry if this is in the wrong spot this forum is a little hard to navigate..
    I've just got a VX Berlina S2 and the aircompressor is dead.
    Local mechanic said $650 for compressor and $450 for fitting and all the seals etc..
    Now.. I said.. no thats a load of crap.. I can get a brand new compressor on eBay for $399.
    But!!
    Ive spotted one second hand for $25 !!
    However.. its from a VZ not a VT/VX/VY ... So.. Will it fit??
    Cant find any info in the search and cant find anything on google.
    VX Berlina S2
    Feb 2010
    Might as well leave this up for discussion.
    vx s pack II
    Jan 2010
    aLKIDA
    If you have to replace your compressor in your car you have to purge the system first (Suck the refrigerant out or recover it)
    You can not let the refrigerant go out into the atmosphere it is illegal and heavy fines apply.
    Then after the purge then you can take the compressor of and fit in a new one.
    And then since the system has been open you need to get the moisture out so you need to evacuate it.
    Then you can charge the system (fill refrigerant in the system)
    You wont be able to do this your self. Unless your a license Air-con tec.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by pablo View Post
    Also, a new filter/drier is recommended by the air con experts.
    Silly me that is true i should of wrote that down. Sliped my memory.
    Too many drinks of scotch
    VX Berlina S2
    Feb 2010
    Some good advice!
    No way on earth am I attempting this install myself.
    I was just shocked by my quote.
    $650 for a new one!!! and $450 for fitting!!!
    So I found a second hand unit for $60 and I'm paying my mechanic the $450 for fitting. That includes new filter/seals + remove gas + regas.
    If he tells me the $60 aircompressor ( That is from a wrecked VX with very low Km's ) is no good then I'll buy a new one from ebay for $350 and still save money.
    Flipping hate mechanics who charge you the earth for parts then turn around and charge you the universe for labor aswell. I respect the skills they have but its pathetic how much they charge.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by VXberlinas2 View Post
    Some good advice!
    Here in sydney the cost depends on the suburb (labour)
    In the west its cheaper and the east its more expensive.
    VX Berlina S2
    Feb 2010
    So they can charge a different price depending on the suburb?? what the..
    More on topic..
    Just out of interest.. Will a VZ compressor fit in a VX? ( I've since found a VX one but I'm still interested )
    I was sure the VZ was the 3.6L and the VT, VX, VY are all 3.8L so wouldnt the compression etc etc be different?
    vx s pack II
    Jan 2010
    aLKIDA
    More on topic..
    The VS/VT/VX/VY are ecotec motors the vz uses alloytec motors. Two different motors. So proberly not.
    Dec 2009
    Have you tried an auto elec they usually do aircons. Does yours still have gas in it? I can't see it taking anymore than an hour or two to put on a compressor, the seals are just where the hoses bolt on and a friend recently got his regassed for about $70. Recfiever driers are fairly inexpensive as well and probably need to be replaced with a compressor but as yours is second hand maybe no need.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    $450 seems alot to fit,the one in my old vq was going to cost $100 to fit and $120 to regas.
    VX Berlina S2
    Feb 2010
    hmm.. I think I'll do some calling around.
    Cheers guys will let you know how I go.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by wortus View Post
    To evacuate the system properly it takes 1 hour depending on the pump size. (The longer the pump stays on thye better the system will be)
    And you have to change the receiver drier its common practice.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Mate, you should have said. I could have given you a hand to put it in then all you'd need to do is get it gassed up. It's not really too much of a hassle if you have the ring spanners with ratchets built into them.
    Also, I tested the aircon before I took it out and all works sweet so this compressor should be perfect for you.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  15. #15
    VX Berlina S2
    Feb 2010
    Mick, Cheers man but I didnt think I was able to remove and refit an aircompressor myself? I thought the system had to be de-gassed before I could remove my old unit..
  16. #16
    VX Berlina S2
    Feb 2010
    Well turns out its getting fitted and gassed/ resealed + all the extra crap for $350 this thursday ( guy even comes to my place and does it )
    Not bad at all.
  17. #17
    VX Berlina S2
    Feb 2010
    Ok so All up I paid $450 for fitting.
    Was quoted $350 but he had to replace the TX Valve so $450 +$85 for compressor.
    Not bad.. not bad at all.
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  3. 1 Dead VT
    By VT Berlina 07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2007, 06:47 PM
  4. From the dead!
    By jetspin_vn in forum The Pub
    Last Post: 07-04-2006, 05:03 PM
  5. SWAP: My work for your work!
    By thisispete in forum Swap / Wanted to Buy / Trade
    Last Post: 20-11-2005, 06:55 PM
