Results 1 to 5 of 5
Thread: missing in drive
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Default missing in drive
    hi. have a vt v6 that only misses while driving. while in idle there is no miss but when you start to drive it misses. mechaninc 'thinks' it's an injector but that should miss in idle too!? maybe afm? or o2 sensor? should i reset the ecu? if so how do i do it?
    thanks for any info!!!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If it's missing under load - I'd be sus on the leads or plugs first. Or even a coil before I looked at the injectors.
    If the injector is clogged put a tube of injector cleaner though it.
    and 3 Dangerous non ABS VN's
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A bad lead is the most likely culprit, but could also be the other things mentioned above.
    MY RIDE
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    plugs and leads just replaced. coils swapped around. just found the air filter clogged. cleaning that now. see how that goes but just in case may it be the o2 sensor or afm?
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    well cleaning the filter didn't help. it misses more and more under load. will have to try injector cleaner tomorrow.
  1. To all Member That Don't Drive A Commodore, What Do You Drive:
    By Evolution_Ends_Here in forum The Pub
    Last Post: 07-12-2008, 05:40 PM
  2. VQ Missing
    By vpete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2008, 11:06 AM
  3. what drive "D" do u guys drive in
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2008, 09:45 AM
  4. VS Missing
    By Frog4364 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2008, 01:57 AM
  5. to drive or not to drive- shredded cable
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 05:16 PM
