Results 1 to 25 of 25
Thread: Help with VX front bumper?
    2002 VXII S
    Sep 2009
    Exclamation Help with VX front bumper?
    Hey guys I need a bit of help. I went to drop my missus' sister off at work this morning and long story short my front bumper got stuck on this prick of driveway. Instead of causing more damage I reversed out which has seems to pull the whole bottom forward
    I had a quick look before work and its closed the gap so I can't open the bonnet. What's my best go for fixing it without any major damage, if its not already done?
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    try the bonnet release w/ someone holding it up, and try to lift the bonnet up w/ force. just my idea
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Just try and push it back into place , undo the screws at each side of the bar near the wheels and push it forward and it should pop back into place .It just clips on and the screws hold it in place .
    2002 VXII S
    Sep 2009
    Thanks for the advice. Yeah its wedged up so I can't open the bonnet, is there another releace for it somewhere?
    VX S S2
    Dec 2007
    Laidley, QLD
    try both suggestions already listed.have had to do it when i let some wank drive my car and they did the same thing.......
    2002 VXII S
    Sep 2009
    VT S PAC 5 SPEED SII
    Jan 2009
    brisbane
    happened to me a while ago but sounds like u got stuck bad i just bashed it back on lol
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    yea unfortunatly the damage is done. genuine bumpers dont have a memory and are hard to bend back.
    it will never be the same and line up properly.
    if your picky like me then your up for a new bumper. otherwise youll get it close to what it was.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by Dayvo View Post
    not where it screws into the radiator support. once its bent its bent
    VX S S2
    Dec 2007
    Laidley, QLD
    Quote Originally Posted by Ozzie View Post
    well actually, if your smart, you will pop big washers under the screws there and as you screw them back in the pressure on the washers will transfer to the plastic of the spoiler, making it almost flat again
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by Rubber_Burnin_Gal View Post
    im smart enough to know that those washers come standard.
    i also hit a kangaroo so i know it dont bend back
    VX S S2
    Dec 2007
    Laidley, QLD
    no they dont, and if you read properly he only scraped it on a drive way, not hit a bloody roo, i should know it can be fixed to just about new the way i suggested(using metal, not plastic washers) as ive had to do it to my own car.......
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    do you wear glasses? if not i suggest you have your eyes checked.
    HE BENT IT UPWARD the washers will hold it yes... but the plastic bends because they are holding it.
    they also come standard with big METAL washers. YOU CANT REMOVE THE WASHERS FROM THE SCREWS
    go double check if in doubt.
    VX S S2
    Dec 2007
    Laidley, QLD
    OMFG what a Warrnambool WANKER they do not come with BIG washers on the screws....... uhhh and obviously mine also got bent upwards if the same thing happened to mine as it did his.... anyways, enough with you **insert face palm here**
    abclarke, IF there is a crease in the plastic of the bumper(under the bonnet) try what i suggested, if that doesnt work, take the spoiler off, get a mate to help and heat the plastic(where the crease is) and with 2 flat metal plates gently flatten the crease again.
  15. #15
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    If you have beef with me take it into pm.
    The guy asked for help, not crap from an a*hole
  16. #16
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Lol - I ripped my VX bumper clean off a couple of times. Just screwed it back on and nobody could tell the difference.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  17. #17
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Reaper
    Yeah sometimes u can get away with it. Its never the same though. People might not see the difference but its always in the back of your mind the damage is there.
    But as I said, Im picky. I know where every chip and dent is lol
  18. #18
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
    so howd it go abclarke?
    im the same, i hate driving w/ damaged bits, main reason im replacing the front.
  19. #19
    Reaper's Avatar
    Aug 2004
    You couldn't tell the difference from the outside but then I hit a kangaroo and that kinda put the last nail in it's coffin. I liked that car - the only one I have ever bought new and made $$$ on
    Reaper
    Reapers Black VP SS
  20. #20
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I had a wombat help me remove mine.I managed to fix it but the clips either side of the bar near the indicators have both snapped off and it doesn't line up with the front guard properly. Holden don't sell the clips as they are heat welded to the bar .
  21. #21
    2002 VXII S
    Sep 2009
    Yeah thanks for the tips guys. I made up a few rubber washers just in case and it worked a dream. Looks like new
  22. #22
    VX S S2
    Dec 2007
    Laidley, QLD
  23. #23
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
  24. #24
    VX Clubby
    Mar 2010
    Default bumper
    hey i have a vx clubby same issue. the clips on the side have come off. is there any other screws i need to remove or should i just be able to pull it off.
    cheers
    keano
  25. #25
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Not sure about the Clubby but there should be a couple of screws on the sides of the bar near the front wheels. Then have a look where it screws to the body under the bonnet .
  1. Will a VT HSV front bumper fit a 94 VR
    By arc angel vn ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2010, 11:21 AM
  2. [NSW] VT front driver guard, front bumper and bonnet
    By nilprapai in forum Swap / Wanted to Buy / Trade
    Last Post: 22-07-2009, 10:15 PM
  3. Wtb Vp Front Bumper
    By madvrcom in forum Swap / Wanted to Buy / Trade
    Last Post: 11-09-2007, 12:03 AM
  4. WTB: VK door, front bumper, front right quarter panel
    By craigvk in forum Swap / Wanted to Buy / Trade
    Last Post: 05-07-2006, 05:02 PM
