Results 1 to 2 of 2
Thread: Cracked fibreglass front bumper
    98 VT Berlina
    Jul 2009
    Default Cracked fibreglass front bumper
    Hey just a quick one
    Me n my mate are going to try fix up his front bumper that has two cracks in it, from when he hit a curb.
    now im pretty good when it comes to painting etc. but im just curious if theres a tutorial on here, or if anyone has any information on the steps need to be taken.
    any help is apreciated
    thanx
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    ok...step 1 remove broken bit from car..carefully
    step 2 clean broken area and surrounds of all road grime
    step 3 sand all loose fibre out of glass
    step 4 apply repair coats of fibre sheets and paint with fibre cement paste (if possible run the grain alternate ways in each layer..(note on the unseen side you can leave a patch proud of the surface area and coving a little more than the hole...once dry it can be painted...)
    step 5 if the hole came through and shows on the front surface...the viewing surface.. fill the balance of the hole with putty ...body filler as you would a car repair....
    step 6 sand the front surface....done to 800 grit....and apply a sealing coat of primer..
    step 7... finishing coat matching the body ...and lite sand with 800
    step 8 ...a coat of clear...
    JOB done..making sure you wipe clean with solvant before you sand and paint
    and make sure you do ruff sanding with 100/200/400 and finals with 800/1000 using water always
  1. Cracked bumper :( car bra???
    By henrytad in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-03-2010, 08:52 AM
  2. [QLD] Vr-s Front Fibreglass Bumper Looks Like Vz?, green and silver with mesh
    By Gus The Snail in forum Parts And Other Items For Sale
    Last Post: 30-11-2009, 05:48 AM
  3. How to Fix Cracked Bumper!
    By Silver_VS_II in forum General
    Last Post: 31-07-2009, 07:36 PM
  4. F.S Fibreglass VR/VS SS front bumper inserts - redbank plains
    Last Post: 19-09-2008, 11:06 PM
  5. WTB:VN/VP fibreglass front bumper CHEAP
    By potshots007 in forum Swap / Wanted to Buy / Trade
    Last Post: 07-07-2006, 10:11 PM
