Results 1 to 8 of 8
Thread: Vt Passanger Power Window Dropped
    vt berlina S2
    Mar 2010
    Default Vt Passanger Power Window Dropped
    was out about today and wound my passanger side power window down and it get going and dropped i manged to get the trim of and suss out the problem the motor is fine but the runner arm had fallen out the trouble is i have no idea how to get the two back together it seems like it was just dodgily glued togetther help would be much appreciated of how to link the two i will put some pics of it up aswell
    and also there are about five holes in it dont where to attach the power window arm.
    Thanks
    Steven
    thinking i could maybe drill a hole in the one in my hand and insert a small nut and bolt?
    vt berlina S2
    Mar 2010
    i downloaded the pdf manual but does seem to mention power windows in it.
    vt berlina S2
    Mar 2010
    found a broken clip in the top runner which i will get a replacement but have no idea how the scissor arm connect back up obviously one in the top and one in the bottom but from there i have no idea.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Nip down to your local wreckers and have a look at how they are put together. You might have to buy a replacement one
    vt berlina S2
    Mar 2010
    yeah was hard today with public holiday but a bloke at repco helped me said the regulator was broken so i 'm trying to track one down without having to buy a new one does anyone know how much im roughly looking at for a secondhand or a new one? then installing it is the next problem.
    vt berlina S2
    Mar 2010
    ok all good picked one up from the wreckers for $50 and $35 install doesn't seem to bad to me.
    VX Commodore S Pack
    Nov 2011
    Glenorie NSW
    I've had the same problem. Can you just replace the arm assembly without having to buy the whole motor for the window etc? Where does that third arm go? I can find the two that go in the bottom guides, but don't know where the third arm (that dropped out) would go.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by stevenj48 View Post
    Select Main Menu
    Select VT Series 1
    Select External Fittings
    Select Section 1A5 Front and Rear Door Assemblies
  1. passanger window question
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-10-2009, 11:18 PM
  2. [VIC] VP/VN/VR/VS Power Window Kit
    By B3ND3R in forum Parts And Other Items For Sale
    Last Post: 03-07-2009, 10:55 PM
  3. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  4. Front Window just dropped
    By VicVXBerlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2007, 08:50 PM
  5. power window
    By snotta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2005, 10:55 PM
