Results 1 to 6 of 6
Thread: No Aircon
    Jan 2008
    NSW
    Default No Aircon
    Hey all,
    I have a VT and the Air con has sht itself in the past 5 or so months, but the heater works fine. I was told that the A/C compressor needed replacing but I having he's trying to take me for a ride. Is it true that a leaking heater tap would also affect cooling and how do you tell if its leaking? I want to try the cheaper fix first before i fork out 500 for a new compressor.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Hey Mate.
    I Would say the compressor is stuffed from what you have said.
    As for the leaking heater tap, if its still open, you will have hot water going to the heater core just as if you turned the heater on, so it will be heating up the car. Heater taps are quite cheap to just replace anyway.
    Can you here the compressor click on when the AC is pressed?
    Jan 2008
    NSW
    I think it clicks or maybe thats just the thermos turning on, i'll listen for it next time. What does it mean if it does?
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    If It clicks on, and takes strain on the car, the compressor may still be working, I would take it to a aircon specialist if you don't trust the mechanic.
    Oh and also check for the passenger side Thermo fan kicks in as thats the aircon fan.
    VX Berlina S2
    Feb 2010
    Loads of info on this thread I started a few weeks back mate. VT/VX take the same aircompressor.
    VX Aircompressor - Dead.. Will a VZ aircompressor fit/work?
    Turns out you can get them much cheaper on eBay and even on forums like this! I picked up a second hand one for $85.
    Fitting + Gassing ~ $350
    Jan 2008
    NSW
    Thanks mate. I can get 1 at trade price for $300 and $190 for fitting and regas. Was just hoping it was a cheaper fix, something small, something other than the compressor hahaha. Well thats cars for ya.
  1. Aircon from VS into VN
    By vsspack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2010, 09:23 AM
  2. aircon
    By vscaprice5.0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2010, 04:23 PM
  3. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  4. VS AirCon
    By Quicksilver in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2006, 05:53 PM
  5. VH Aircon?
    By pro_gmh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-11-2005, 02:36 PM
