Results 1 to 4 of 4
Thread: vt power window wont go down
    vp
    Feb 2009
    Default vt power window wont go down
    I have a VTII and my rear window will not go down, it did go down about a 1/3 of the way slowly and go back up without any issues, but now it wont go down at all. I can hear it click in the door when I push the button either on the door or in the front.
    its not the switch as I have changed both of them.
    Any ideas???
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    probly the wires between the door and the car body. if u buy a new loom that goes from the door to the body it will run smoothy. alternitivly is what i did and thats cut and solder in new wires, i used heat shrink to cover. also use black silicon on the plug that goes into the body as water will get in there.
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    use a cable tester to see if there is power going to the motor, if not, its your wiring, if there is, its probably the motor.
    vp
    Feb 2009
    thanks guys, will check
  1. vn calais power window wont open or shut
    By grovers_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2010, 08:53 PM
  2. VT Power window wont go up!!
    By mbvp73 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2010, 09:21 AM
  3. Drivers side power window goes up but wont go down
    By Scott VT 1998 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-10-2008, 02:19 PM
  4. VX Clubby Window wont go up!
    By StealthX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-09-2007, 08:07 PM
  5. Window wont go up
    By greg644 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2007, 05:02 PM
