Results 1 to 5 of 5
Thread: vt engine light on and off when i accelerate
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Default vt engine light on and off when i accelerate
    Hey guy i have been trying to fix this problem now for a month now with no luck ,my problem is when i am driving around the engine light comes on and goes off when i accelerate and also when the engine light comes on the fuel instance stops working on the level 3 dash and sit sat 0.0 and starts again when the engine light turns off, if anybody knows whats is going on let me know as i am about to start kicking panels .
    cheers bbhopper
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    that sounds like a bad earth....on the system....
    do this....
    1) check the codes on error report of cars computer and see what it says...
    fix anything linked to your current issue...
    then...
    remove and replace every relay and spray every relay out with wd40 and blow out with air after leaving the wd 40 in for 1hr...
    remove and clean all fuses ...everywhere...under the bonnet and under the dash...
    clean the battery terminals...and pull the battery leads apart and clean all parts
    undo and clean with a steel brush all the cars earths straps..
    and unplug and clean with wd40 all sensors ..as well
    Try that first....
    then try undoing and redoing the leads that run into the computer on the car..and check its earth strap...
    after that...cry....
    hope that all helps
    Dec 2009
    east of melbourne
    Hey code thanks for that i have done the computer check and i have code 92 and code 48 i have replaced the cas today and reset it with my efilive fingers crossed there code 92 well thats been there since i brought the car ,but i have got the low speed working fine i just removed the high speed relay and the low speed function fine ,so i was leaning that way towards a earth problem also i forgot to mention that somtimes the oil light somtimes comes on and stay on and goes off with engine light but that is only once or twice in the last month ,would you know where all the earth points are located or are they fairly obvious i know of the one from the batt to the body near where the abs sits ,the one in the inner guard near battery are there any more you know off like in the car etc if you know of anymore let me know and i will do it all this weekend and ill post back my outcome but i cant think of anything else
    thanks for the reply and will let you know
    cheers chris
    Dec 2009
    east of melbourne
    hey code thanks mate your a legend i went out the other night and found my problem it was the earth lead from battery to motor the bolt had come loose ,phew thanks god it fixed was really pissing me off thanks mate for your advice would not of thought of it.
    cheers bhopper
    HBD VT Calais SII L67
    Mar 2010
    newcastle
    also are u running any mods like pulley up grade, and stuff like that
    cause i have found with a couple l67 with upping boost, some of them had a engine come on under hard accel and when i chucked our scanner on them they said engine lean under load
    also happened with mine running 13 psi boost and no tune
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. windy noise when i accelerate & engine our problem
    By Adriianz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 04:46 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. Battery light lights when i accelerate?
    By mgut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2008, 06:15 PM
