Results 1 to 8 of 8
Thread: VT V6 battery light
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    Question VT V6 battery light
    not a huge problem however when the vt revs out to 4k and above while accelerating the battery light comes on. volts are at a constant 14.2-3volts. no less no higher.
    and i've noticed that reving past 4k while in Park/Neutral the batery light comes on and the speedo goes to 20km/h... wtf? anyone else notice anything like this?
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    VY SII HBD Calais L67
    Dec 2006
    May be an alternator regulator. I know the volt reading stays the same but the battery light doesn't come on for no reason.
    As long as your battery isn't dead yet (they usually die when a reg goes) I'd try replacing the reg which only costs around $60 for a non genuine like OEX and if that doesn't work the next step is the alternator
    VYII Calais L67
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    regulator is my guess aswell it is a 8-10 month old alternator so thats why i asked as i thought it wouldnt be stuffed.. i have a second hand one so i swap em.
    Dec 2006
    When you fitted the new alternator didn't it come with a new reg as well? If so you should still have a warranty on it
    VYII Calais L67
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    it did. so if the swaping fixes the problem then ill act on the warranty...
    VS Executive
    Nov 2008
    Wollongong
    Belts aren't slipping??? Could it be high revs the belt is giving out? Is anything else affected when you rev that high?
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    nothing else stuffs up, just this light but im not 2 concerned bout it cause it goes away.
  1. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  2. Battery light
    By kaishiz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2010, 11:00 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. battery light on & orange light on
    By smokey.29 in forum Electrical Wiring / Questions
    Last Post: 12-02-2007, 06:16 PM
