Results 1 to 5 of 5
Thread: vt 1998 misses(coughs) under acceleration
    vt
    Mar 2010
    Default vt 1998 misses(coughs) under acceleration
    Hi guys, i have a 1998 vt which has started to miss under acceleration.if you are very light footed you can get up to speed without it missing, but normal driving it'll miss. once up to speed it seems happy to stay there without a problem..Anything simple to check before i take to the mechanic?..will check the leads etc and also seen someone mention the airflow sensor in vt get dirty..is this easily to check?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Plugs or leads are the most likely suspects. If they haven't been changed in years then it wouldn't hurt to replace them.
    MY RIDE
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    What he said, check all your leads are securely on the plugs. If so, replace the plugs and if that doesn't help, then the leads.
    If you don't want to spend money unnecessarily see if you can borrow a friends plugs/leads to test.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    Supercharged VX S
    Nov 2006
    As Mick1988 and accentstencil said I'd be going with plugs, this happens when mine plugs are getting older. How many klms since they were change last. Plugs are not expensive to change over.
    vt
    Mar 2010
    thanks guys...havent had it for very long, so not sure when they were changed last..went and bought a set of leads, plugs and a haynes repair manual for a $140. fitted the leads and plugs and so far seems to have fixed it....forgot to mention, it also has that climate control problem were under hard accelleration the air diverts up to the windscreen vents..seen on here that its probably a vaccum leek somewhere, so will look at that one on the weekend
  1. 5.7 coughs and splatters when i put power into it.
    By Con D in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2009, 12:31 AM
  2. Car Dies at high revs coughs bad fuel?
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-02-2009, 07:47 PM
  3. runs rough, coughs and dies????
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 03:57 PM
  4. Misses In First
    By enhancepc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2006, 04:54 PM
  5. VP 5.0l coughs and splutters
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2005, 09:41 AM
