Results 1 to 3 of 3
Thread: Changing an Auto to Manual Ecotec
    vs 5.0l
    Feb 2007
    Default Changing an Auto to Manual Ecotec
    Hit there,
    Thinkin of buying a vt s-pack (manual) with a blown motor and a mates low kms stacked vt to change motors over. has anyone done this. does the manual bolt strait up to an auto motor. Is there anythin else i need to do or to look out for.
    Have had a quick search but couldn't find the info i needed. Any links would help
    2000 VX Berlina
    Dec 2008
    it will bolt up but you will have to use the wiring loom from the manual car.
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    Easy to do,since you have 2 cars to make one out of you will have everything needed to complete the job. Since your putting the engine into a manual car all you have to do is pull the motor out of the auto,unbolt everything including the loom & drop it in. A tip is to pull the whole motor & box out together,then put it in the same way. Remember to plug up the end of your gearbox so oil doesnt run out. Have fun
  1. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  2. Manual Changing in an Auto?
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2009, 12:04 AM
  3. changing from auto to manual
    By big balls in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2009, 08:12 PM
  4. changing ECU auto to manual
    By RabidDog_12345 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2007, 01:27 AM
  5. Changing A Vl From Auto To Manual
    By vl_lightening in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-04-2004, 09:18 PM
