Results 1 to 6 of 6
Thread: vt wont start
    stock vt
    Mar 2010
    Default vt wont start
    hay hay my vt has fully charged battery has ing lights but wont turn over at all?
    has had new key for 3 mounths was goin fine but not now hay...
    ve sv6
    Mar 2010
    green point, gosford, nsw
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    vx s pack II
    Jan 2010
    aLKIDA
    Could be starter/relay/Inhibiter switch (if automatic.)
    It also can be the Security system. BCM/KEY/READER.
    Check for fault codes bridge pins 5/6 on the diagnostic connector.
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    it wont turn over at all....meaning it trys like you hear the relay and starter motor click then nothing....or you dont hear anything..
    have a person watch the engine and see if the belt mopves at all and if a relay and stater motor solinode clicks...
    if it dont ....move but does click...
    or if it moves only a little...try it without the plugs in it....remove all of them...
    and even take off the fan belt ...
    if your engine wont spin over with this done..or it spins then locks up...you have a cyclinder or valve or timing chain issue...
    also check you not by accident overfilled engine oil...its been done!
    or been driving through water and have a new bunning super sucker cai homebrew...and have sucked up water into the car..
    or you got white oil now...by checking the dipstick.....due to cracked head or gasket..
    why am i mentioning all these things...because you not detailed the story enough
    so it could be a faulty starter motor or starter solinode
    or bad contacts to battery..even if you have lights..
    or bad battery lights need min amps compared to starter and running...
    or as mentioned by others..
    dont let the vt beat you
  1. VL wont start yet again..
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-12-2009, 11:56 AM
  2. Vn wont start
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2009, 12:26 AM
  3. Vt wont start and run
    By bladerunnerkim in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2009, 12:10 PM
  4. Vr V6 Wont start...
    By hdt 01 in forum Electrical Wiring / Questions
    Last Post: 07-04-2008, 07:39 PM
  5. The VN wont start!
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 12:27 AM
