Results 1 to 4 of 4
Thread: revs keep on riseing when i shift gears
    vx holden s pack 3.8
    Mar 2010
    cairns
    Default want advice
    i have a holden vx v6 supercharged and i want to put a 10 psi pully on and was wondering if it has to run using 98 octain fule or can just use the 95 is there any difference and if i use the 95 will it do any damage to it ......
    Last edited by ccman22; 12-03-2011 at 04:00 PM. Reason: need to know smoething new
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    what about your TPI switch,it could be faulty or alternatively something simple like accelerator linkages
    Mar 2010
    cairns
    whats a TPI switch not sure what it is ive changed my accelerator cable and changed the to sensors on the throtle body
    vt s-pac
    Feb 2010
    change the compuiter or change the tps(borrow a mates compuiter first) then buy one if that worked
  1. VN V8 Auto Transmission Issue (High Revs, 4 gears)
    By 8rody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2010, 12:16 PM
  2. 3.73 diff gears and a stage 2 shift kit
    By H.I.M666 in forum General
    Last Post: 05-07-2009, 12:48 PM
  3. Good V6 diff gears for higher revs
    By hamishdean in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2009, 01:01 PM
  4. diff gears and shift kit...
    By Slow_Az in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-07-2006, 12:43 PM
  5. revs to high and gears not shifting right
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2005, 04:35 PM
