Results 1 to 14 of 14
Thread: More problems
    SSZ 5.7LTR & 01 VX V6 Supercharged
    Aug 2009
    Toowoomba
    Default More problems
    Ok so the VX previous history is rebuilt engine etc... and problems with lack of power ever since it blew.
    All sensors replaced ,scanned etc..everything shows up good.
    Well just now the missus driving home and all the dash lights light up from left to right then clearing, it did that same sequence about 3-4 times. I had her leave it running and now its sitting here with ABS, and trac light on, but none of the gauges work speedo, RPM and theres no digital read out ie...fuel, km etc...
    Im trying to find a bloody paper clip to check the codes..
    Any ideas guys? I allready have the abs module in the back of my mind but totally no gauges working ? im not sure.
    Aug 2009
    Toowoomba
    OK the dash wont stay stable long enough for me to count the codes, it shuts all functions down aprat from ABS and trac.
    You guys wont believe how close I am to pushing this car off a cliff and claiming insurance, ive had a gut full.
    Nov 2003
    Is there anything you changed or didn't change when you put the new motor in. I would be thinking something electrical.
    Aug 2009
    Toowoomba
    Nah its all the same since the rebuild apart from all new sensors to fault find the lack of power. Im thinking electrical to, like possibly it partially fried the ECU when it blew and has slowly degraded since. Because aside from lack of power it uses alot of fuel and the distance to go read out is allways recalibrating, ie...from start it could say 180km to go then driving 3km it will say I have 75km worth of fuel to go.
    Nov 2003
    I haven't had much to do with commodores, well at least working on them for years, so I will be relying on some help from you. I am wondering what it is that controls the guages is it the PCM or BCM. If its the PCM is the chip removable and if it is are all PCM's the same for a givern model and it's only the chip that is different. I read that the PCM and BCM are matched to each other. I was gonna suggest if you can get a wrecker special BCM and PCM wack them in on the provision that the chip is the only difference between the commodore models as I noticed you have a supercharged VX.
    Aug 2009
    Toowoomba
    Thanks also for the response Locksmiff,
    You just reminded me I have a spare chip I can try to clear this new problem, at least that way I will know its not the chip and it is indeed something else . Only draw back with that is the chip is a blackstar7000 LOL.
    Quote Originally Posted by Locksmiff View Post
    Nov 2003
    I have been doing a bit of reading. It won't be the BCM. I personally don't think it will be the chip as it doesn't explain the odd dash issues. Is all the wiring perfect, nothing got exposed or pinched when putting the motor back in after the motor rebuild. I feel it maybe shorting somewhere or has shorted and maybe caused an issue with the PCM.
    I may have it assed about as well so take it with a grain of salt. I am remembering back to my VN and its ECU (PCM) its dash wiring went into the ECU (PCM)
    Aug 2009
    Toowoomba
    Well I got nothing better to do today, missus Is now at work with my SS : So I might as well grab a torch and start searching.
    One would think that between Holden and the other performance shops That looked at it , one of them should have found a problem long ago.
    Nov 2003
    Quote Originally Posted by D_BLOCK View Post
    You would think so would'nt you.
    VX Executive S2
    May 2006
    Frankston South Vic
    Aug 2009
    Toowoomba
    I would have tried that but my whole display would go blank , apart from trac and ABS.
    I have just cleared the warning lights by pulling apart the ABS module and cleaning the contacts (just a temp fix I know).
    Now I see theres a connector plug with a small box thats missing from the alternator, not the 2 screw unit that holds the brushes, the other end, whats that piece called?
    Its snapped right off and just has the plastic sleeve over the contact. Im beginning to wonder WTF the wifes doing to this car?!?!?
    Aug 2009
    Toowoomba
    Ok I found the part its some sort of resistor to quiet the alternator down. Its not needed and doesnt come shipped brand new with one ,so bugger it.
    But I need a new alternator as the guts of mine is burnt out.
    Wheres that cliff?????
    Thanks for the help guys.
    Nov 2003
    Aug 2009
    Toowoomba
    Who did the engine rebuild, you or someone else ??
    It was a workshop in brissy.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  3. few problems
    By a47b in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2009, 05:03 PM
  4. 2 Problems??
    By SiLeNt-SoN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2007, 09:04 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
