Results 1 to 10 of 10
Thread: VT will turn over but wont fire?!
    1990 VN Waggy
    Oct 2009
    Brisbane, QLD
    Exclamation VT will turn over but wont fire?!
    Hi guys,
    I've been having a bit of trouble with my dad's V6 VT, most time when i try to start it, it will crank over but never fire.. leave it 30 mins, Bam fires first time(But not always sometimes it wont start for a whole day). My dad thinks it may be an immoboliser problem in the key but the key is only a couple of months old. Please help!
    VN WAGGY! Bur Bur Bur Bur
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Is the security light off or flashing when it won't start?
    MY RIDE
    1990 VN Waggy
    Oct 2009
    Brisbane, QLD
    Is the security light the esclamation mark in the circle with brackets around it? If so then it just stays on. I just went down stairs and it starting 4 times in a row with no problems at all so i don't have a clue whats worng with it..
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    The security light is the red LED that blinks in the Trip Computer (MODE) switch housing. BCM might need replacing, it's a bit pricey but hey, a car needs to start.
    I haven't lost my mind, it's backed up on tape somewhere
    HBD VT Calais SII L67
    Mar 2010
    newcastle
    if u leave the ignition on reds for a couple minutes and then try it then if it starts first go, replace the relays for fuel pump,
    happened on a vx at work the other week sometime u could crank the car for ages nothign would happen but leave the ignition on and it would start first time,
    i think some of the relays must build up resistance and not let enough current thru for pump to build initial pressure,
    1990 VN Waggy
    Oct 2009
    Brisbane, QLD
    Quote Originally Posted by s_ikari2015 View Post
    Once the key is turned to ON the light goes out.
    1990 VN Waggy
    Oct 2009
    Brisbane, QLD
    Quote Originally Posted by HBDCalais View Post
    I will give this a try later today, hopefully the problem is that simple.
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    HSV XU6
    May 2010
    Me too! Seems to be about 4-5 cars doing this but all different I guess in terms of mods. I am hoping for the key as I had the car serviced and comes up with no faults at all
    VT Executive S1
    May 2010
    Looks like every one is have trouble with there VT,
  1. Vl wont fire
    By JimayYoung in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-10-2009, 09:36 AM
  2. MY F****n car wont fire
    By vh2nv in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-06-2009, 06:25 PM
  3. vk wont fire up
    By mojo.jojo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2008, 11:06 PM
  4. Vp Wont fire.
    By Haydz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2008, 10:18 PM
  5. Wont Fire!???
    By traindriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-08-2006, 11:28 PM
