hey guys
just driving home just then and when i chucked the high beams on they flickered and went out..flicked back down to low beam and the lights worked fine... tested them when i got home. sometimes they come on and stay on, some times they flicker and stay on, some times they cut out...u's reckon its a shagged relay?
relay or your high beam switch on the column
high beam switch was my second guess...hopefully relay lol
just incase anyone else encounters this problem... remove the high beam relay and pull it apart. pull the contact out of the way and clean the contact points as this was the cause of my high beams cutting out.
