Results 1 to 12 of 12
Thread: Ping!!!
    VT S-Pack 3.8L Supercharged - Rebuilt*
    Feb 2010
    If you have a valid reason for requiring my location, you can ask!
    Default Ping!!!
    hey my engine pings!!! not good. i've been told to change from the normal unleaded fuel to the vortex stuff...u reckon that'll help? or does my car need tuning now that i have a 10psi pulley?it just got put on today.i noticed a noise a while ago but just thought it was a slipping belt.the mechanic told me to watch out for pinging n so i had a real hard listen when i went for a drive later on n now it's real apparent. thoughts would be appreciated
    Feb 2010
    sorry people i don't know the technical term. someone could probably explain it better than me but basically what happens is fuel gets injected and ignites above the pitsons prematurely. sounds like someone throwing a handful of gravel at you engine.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Technically it's called Detonation, take some timing out of it.
    There is no such thing as stupid questions, Only stupid people.
    VY II V6
    Dec 2006
    Go put some premium unleaded (98) in before you take it to a tuner.. The stock tune should have enough scope in it, provided you use good fuel..
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    Feb 2010
    detonation, that's right.cool cool, as soon as i get rid of the old fuel i'll put the good stuff in. deliberately drove half a tank today LOL. but ye a mate of mine did the same thing and he didn't need to tune it at all. but then again when he did it it was like 5 years ago when they probably weren't putting as much crap in the fuel. thanks for the help.
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    Your car is an L67 with a 10psi pulley on it right. Easiest thing to do is just to run it on BP 98 (Ultimate) all the time. Will stop the detonation and is what you will need to put in every time to keep the super 6 happy.
    Feb 2010
    Quote Originally Posted by Dan VS 231 View Post
    ye that's it. well ye i was told to use that or V-Power
    vx calais superc6
    Sep 2008
    there rite gota use 98 octane once u got that 10psi pulley , should use it if u dont .
    VP Executive R-spec
    Jan 2005
    You can either run less timing, better fuel or less boost. Or get a cooler
    Feb 2010
    ye i'll go with the fuel. nearly at empty now. gonna try to use as much as possible tomorrow then i'm up for a fortune in petrol lol
  1. Ping and knock noise on start up VE manual 6.0 Litre?
    By mooks6669 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-08-2009, 09:36 PM
  2. Occasional ping from engine bay while driving
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2008, 09:22 PM
  3. black smoke, oil/coolant loss, ping when cold
    By kremprod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2006, 09:04 PM
