Results 1 to 8 of 8
Thread: VR stroker into VT SS
    VZ Calais
    Aug 2005
    Mackay Qld
    Default VR stroker into VT SS
    Hi guys, I thought i would post this up. I have a m8 considering buying a VR with a 355, so he can swap the engine into his 5L VT SS.
    What problems are we likely to encounter?
    VR has T-5, VT has getrag.
    Cheers, Col.
    VXII
    Nov 2009
    ...fail when it comes to rego renewal time.
    Engine can't be older than the car.
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Quote Originally Posted by moose man View Post
    That seems strange...Are you sure that's right?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VY Berlina V6 / R31 Skyline
    Dec 2008
    That's right mate,
    You can't put an older engine into a new car generally.
    Maybe you can with some very exspensive re-engineering of the motor and exhaust, though it wouldn't be worth it if you could.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VP Executive R-spec
    Jan 2005
    Hi mate technically the above posters are wrong. But I'll try and set it straight. While you can use an engine older than the car it needs to meet the emmisions standard the car came with, For anything in the VL-VS S2 range that's ADR 37/00 so all those engines are interchangable. The problem for you is that the VT ran ADR 37/01 which is a bit stiffer and as with most things in the car making world, nothing gets changed or updated unless it has to and in Australia engines only change when the laws make them. ADR 37/01 runs from the dates 1 / 1 / 1997 - 1 / 1 / 2003 so you have to run engines from that date range or a later ADR.
    Now there's possibly a way you can do this but someone (you) is going to have to find out when the last series 2 5 litre VS's were built before they went to the maf engine. If there were some built during 37/01 (after 1/1/97) then you will be ok to run the earlier motor, if not then legally you will be out of luck, but I mean you would be very unlucky for anyone to notice/care that you were running the earlier 5 litre and 90% of rego places wouldn't know the difference. I will try and find out if there were any ADR 37/01 series 2 VS's.
    Update: There's VS S2 in my family and it's built 10-06-97 which should make it a ADR 37/01 car I'll have to find the ADR on it myself though but so far it looks positive for early 5 litre into VT action
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    You could just install the intake system with the MAF sensor, plug it in to a wire that isn't actually connected if it's a pre-MAF engine
    Not that I would recommend such shifty actions....
    I haven't lost my mind, it's backed up on tape somewhere
    VZ Calais
    Aug 2005
    Mackay Qld
    Cheers for the replies.
    The VT is a series 1 '98.
    Not sure what the engine that is in the VR is from. It could be factory, but not sure.
    VXII
    Nov 2009
    From the RTA website (ther may be other relevant sites for your state):
    Emission standards for replacement engines
    1972 and later model vehicles with substitute engines must meet the intent of the later of the Australian Design
    Rules applicable to either:
    a) The original vehicle; or
    b) The substitute engine.
    To ensure continued compliance with emission standards, any replacement engine should come from a vehicle which
    is subject to the same or more stringent emission control requirements. An alternative is for an earlier engine to be
    upgraded during reconditioning to more recent engine specifications. All anti-pollution devices should be fitted and
    functional.
  1. VG 355 stroker
    By Boonz in forum VN - VP - VG - VQ
    Last Post: 11-07-2010, 01:12 PM
  2. 355 or 383 stroker????
    By Zeussy in forum V8 Development and Modification
    Last Post: 25-04-2010, 11:52 AM
  3. 372 stroker
    By jayz383 in forum V8 Development and Modification
    Last Post: 14-05-2009, 08:20 PM
  4. 355 Stroker??
    By Vkcalais8 in forum General
    Last Post: 04-12-2006, 01:29 AM
