Results 1 to 4 of 4
Thread: LS1 auto rebuild question
    Nanos's Avatar
    Nanos is offline Not a Mod
    VXII LS1 Berlina Wagon
    Aug 2007
    Frankston
    Default LS1 auto rebuild question
    I'm in the process of getting yet again another auto rebuilt.
    The box just blew had all the normal upgrades (beast shell, wider bands, extra clutches etc..). The only part that wasnt done was the valve body or solonoids.
    The reason the auto place gave was no point due to the tune being able to control everything.
    Now its going to be rebuilt again im asked the auto trans place should we put a better valve body in (such as transgo) he replied with the same answer. no point because your tune can adjust everything.
    Im after everyones opinions. Should i request him to do it or is he right in the fact that i can just adjust the tune to suit (which has been done).
    i should add what has gone in the trans is 3rd and 4th gear clutches. trans had done 80,000+kms and was driven hard with load all the time so i dont htink anything but normal wear and tear wrecked the trans.
    HBD VT Calais SII L67
    Mar 2010
    newcastle
    What exactly was burnt or destroyed
    do you have any valve upgrades other then the stock ones in there?, i would suggest u get then valve changed in the pump that control line pressure, the stock one when go pedal jumped on only slowly increases line pressure, where as there is an after market version that as soon as u open the throttle it gives u full pressure which is much better in a car that gets driven hard,
    and a tune cannot alter that valve to open any faster or slower,
    as for valve body the stock one is adequate you could ask to get your feed holes in the seperator plate drilled out so can get oil to your pistons and servo quicker reducing slip time while applying next gear, but if they go to large u run the risk of blowing the top off your 3/4 drum as they are only made of cast alloy and not extremely strong
    Nanos's Avatar
    Aug 2007
    Frankston
    the box is still being stripped down, dropped off today. but from road test the trans place seems to think 3rd and 4th clutches are gone.
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    Same thing happened to my brothers vy turbo. 3rd and 4th clutches. Was only just over a grand to fix with everything that was broken being upgraded as well as the pressure lines being modified. Also got an upgraded valvebody.
  1. V6 auto rebuild
    By drift-it in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2009, 04:46 PM
  2. VR 5.0 auto rebuild
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2007, 03:06 PM
  3. DIY Auto rebuild
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2007, 05:43 PM
  4. VS V6 Auto rebuild
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2006, 04:22 PM
  5. vs auto rebuild
    By danny1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2006, 07:55 PM
