Results 1 to 18 of 18
Thread: clutch removal
    cammed Vx ss m6
    Sep 2006
    Default clutch removal
    how hard is it to replace a clutch in a 6speed manual ls1? id assume the tranmisson has to come out and everything, my clutch is on its way out and want to replace with a zgrip or something similar and was thinking itd be a good time over easter. I dont have any cash to pay mechanics as im going to bali and need the $$ haha.
    cammed Vx ss m6
    Sep 2006
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    well its not a fun job even when the cars on a hoist, remove shifter , remove exhaust,remove tailshaft, remove clutch fluid line, split the box from the bellhousing, take the bellhousing off, clutch pressure plate off, flywheel off, remove spigot bearing, replace spigot bearing, fit flywheel, fit clutch assembly and use a proper alignment tool (you will be so much happier when the input shaft just slides in.....) bellhousing on, gearbox back on, fit clutch fluid line and buy a bleed nipple adaptor from extreme clutches (so you can bleed it without it being a raging homo...) check rubber couplings on tailshaft for cracks, tailshaft on, exhaust back on, shifter on....
    thats about it, but its not as easy as it sounds even with the right tools and experience
    had quite a bit of practice and theres been alot of "kind" words exchanged with some cars
    cammed Vx ss m6
    Sep 2006
    haha **** looks like ill just send it to mechanics after bali then. I might aswell buy some diff gears at the same time haha
    Boonz's Avatar
    Jul 2005
    i also rekon with those tex clutches that the warranty bit says its only valid if fitted by a qualified mechanic :P so its probably worth getting done properly... have a mate who broke a twin plate clutch from that mob after 430 k's and they swapped it for another one with no questions asked. pretty good service if anything does go wrong with it
    cammed Vx ss m6
    Sep 2006
    my next door neighbour is a mechanic so worse case i do it myself couldnt he just say he done it not like they'll check haha. im not worried about undoing bolts and shit ill ring see how much they'll charge but im not made of money and dont mind giving it a crack haha. is it possible to do stands or does it have to be on a hoist
    Boonz's Avatar
    Jul 2005
    think they need a repair order for warranty if they ask, pretty reliable clutches tho you shouldnt have a problem...
    it would be best to have some 2.5 (ish) tonne jack stands and a creeper to roll around on
    cammed Vx ss m6
    Sep 2006
    yeah thats cool worst case scenario i get some one to mock it up. I have a few stands and jacks and can borrow some from work aswell. I think ill end up having a crack worst case ill get it towed somewhere haha
    cammed Vx ss m6
    Sep 2006
    alright so im half way through this and got one bolt left on drivers side at top connecting tranny to block .... any tips on how to reach it haha i had a few cracks but getting dark outside now and had like 4 extensions and swivels trying to reach it haha
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    cammed Vx ss m6
    Sep 2006
    mate next door is a mechanic but he goes motorbike ridding weekends haha everything was easy upto these bolts and now i am sinking the beers thinking for ideas
    vt s s1
    Mar 2009
    Its a pretty big job but definately not one of too much difficulty.
    Hardest thing to do would be replacing spigot and make sure the clutch is alligned properly.
    Rest might seem complicated but its realistically only a few nuts and bolts just takes some time and patience.
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    lay on ur motor and reach in there with a ratchet spanner thats wat i did, pain in the arse but at least u can get to them lol
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    cammed Vx ss m6
    Sep 2006
    i got it done last weekend. dunno what you took off mate but there was no way to get to it from the engine bay haha bunch of wires that i didnt want to trace back to remove
  15. #15
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    How many hours did it take you to do the job?
    Did you replace the flywheel or get it machined? And what did you do alignment wise, the Holden manual says that you need to push the spline in with a lever or something...weird.
  16. #16
    cammed Vx ss m6
    Sep 2006
    pretty much 10am till 4pm over 2days altho i had a carton of coronas handy. Personally its worth the money paying someone to do it haha. The clutch i got came with new clutch plate and flywheel and i used a plastic alignmeant tool i got from a preformance shop when i brought the kit from them.
  17. #17
    Claudy's Avatar
    May 2006
    Perth, Two Rocks
    if u do do it urself, id recommend two people under to take the box out coz its pretty heavy lol and i took it out with the bellhousing and box all in one piece, when u do that, u gotta rotate the box 90 degrees towards the drivers side
    VT V6 Manual turbo
  18. #18
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    I hear there will be a few kind words exhanged between you and the car during the job.
    I hear that the labour cost of the job is quite substantial, which is why I am leaning towards doing it myself, however, but I don't want to be stuck without a car if I stuff it up.
    Anyone had or have any quotes to get the job done?
  1. clutch removal 6 speed
    By m0n4r0 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-11-2009, 09:09 PM
  2. VX Clutch help
    By Tristao in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2009, 10:12 AM
  3. In need of a new clutch
    By trashthumpy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2008, 08:10 AM
  4. vy 6sp clutch
    By gazza m in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-08-2008, 06:37 PM
  5. Clutch on way out???
    By stealth_grey in forum General
    Last Post: 09-03-2006, 11:41 PM
