Results 1 to 3 of 3
Thread: VX LS1 Dash Error Codes
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    Default VX LS1 Dash Error Codes
    I read about putting the dash into the mode to display the diagnostics (mode and up)
    I had a browse around and I have found the error code T17 HC.
    So I know that means History and Current values are set. I cannot find a list of what code 17 means on a VX fitted with LS1. Is it the same as the VT V6 listing, being BCM Fault Logged? If so what does this mean?
    edit: Also no warning lights are on when the dash is in normal mode
    Thanks
    QldKev
    VX Executive S2
    May 2006
    Frankston South Vic
    Hey Kev, 17 is nothing to worry about. the VX had a factory fitted error where the BCM and Display CAN line logged a fault when starting
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    ok, I will ignore it. thanks for the reply.
    QldKev
LinkBacks (?)
  1. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  2. error codes 13 and 33
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2009, 08:02 PM
  3. error codes!!?!?!?!
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 12:10 AM
  4. Error codes Help please
    By WiLo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2006, 09:09 PM
  5. 4 ecu error codes
    By VLACS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-03-2006, 10:13 PM
