Results 1 to 6 of 6
Thread: Vt window wont go down, not the switches, not the regulator, what is it???????
    94 holden belina sedan 5L V8
    Sep 2005
    Auckland, New Zealand
    Default Vt window wont go down, not the switches, not the regulator, what is it???????
    Hi there, i am ripping my hair out on this one, i have just bought a 99 vt ss,
    pass rear window wont go down or up via the main switch in the console at all, but it wants to go up with the switch on the door when you press up (but is already up fully) as you can hear it, the switch on the door is tested and ok, ive cleaned all the contacts on the main switches,
    i also uses a multi meter to test current on the plug that goes into the motor, push up it reads 12 volts so algood there, but when you press down nothing? no voltage so could this be my bcm?
    really need help as the windows are suppost to be tinted next week!!!
    many thanks
    showbags's Avatar
    showbags is online now Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    had the same problem with the same door on my Vt calais, turned out to be the wiring loom in the door.
    VT Berlina Wagon S2 V6
    Sep 2009
    New Zealand
    Hi,
    In my case the motor somehow wasn't working.
    Made the crimp that holds the wining mechanism on the motor a bit tighter and it seems to work fine.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    had same problem on my calais, how i fixed it was take door skin on, get your hand inside door till you can find the steel cable coming off the window motor, gave it a move pulls, seems as though on my car it jams for some reason, but each time it stuffs up i just pull on that steel cable and then it works again perfectly, i spent weeks pulling my hair out also, because there was power at motor, and you could hear it was trying to work, give it a go mate, let us know how you go
    Sep 2005
    well, spent alot of my weekend pulling apart the door trim, took the loom out and a wire had broken in the flexi part between the pillar and the door, all the other wires seemed fine but this had completely snapped, anyway repaired it and now window works sweet az, now all the windows work! for now.... lol cheers guys
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by 3.8L of executive power!! View Post
    oh lol should have mentioned that loom, my wires broke in there too once, wasnt window though, central locking on door was working on and off
  1. vz window switches.
    By doyab in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2010, 08:39 AM
  2. vy window switches into vr
    By roverman88 in forum Electrical Wiring / Questions
    Last Post: 26-01-2009, 04:47 PM
  3. Replies: 18
    Last Post: 03-11-2008, 04:12 PM
  4. Switches Behind Power Window Switches
    By extremeaudiowa in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-05-2007, 10:38 AM
  5. window switches
    By vrstu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2006, 06:18 PM
